Why don't TDI's like winter
Discussion in 'Biodiesel general' started by chef73, Feb 15, 2011.
  1. el_reino
    el_reino New Member
    Jul 1, 2013
    6
    Bora tdi 4-motion 2000
    Hi!
    Hear in Finland large proportion of people driving winter with diesel engined cars. Temperature could be under -25°C to -30°C three months.
    Here is selled special winter diesel, Where is taken out from stearic. Stearic is used to solidify in filter and fuel lines.
    Many use cover in front of the radiator to protect against cold wind and lifting up engine temperature.
    Some use to change higher temperature thermostat range 88°C - 92°C.
    Nowadays in new cars is installed additional heater. Eberspächer , Webasto ETC... Which heats also when driving.
    Almost every car is equipped with electirical water heater. Which helps and protecs on cold start.
    Without nothing of mentioned, engine will run too cold. In the long run that causes bad worn in engine.
    Cheers!
  2. Cogen Man
    Cogen Man Active Member
    Jun 27, 2011
    439
    Golf TDI/2011
    Kingston, Ontario, Canada
    Window tint, window vent visors, ScanGauge II.
    Not by much. Just a waste of diesel. Diesel's are much more efficient than a gasser. A gasser rejects a lot more heat to the cooling system thus warming up the coolant faster.
    I don't do the rad block. What I do is zip tie some 1/2" foam pipe insulation in the lower grill slots. Probably doesn't restrict the cold air much but a little bit do's help some. my two cents
  3. sette
    sette Member
    Mar 22, 2014
    32
    golf V tdi
    trento
    I put some alluminium sheet on the intercooler during the winter to stop the freezze air in such and the mpg increase near the summer mpg (little less the the summer), during the summer i take off the sheet and it goes well. Hope this helps mpg's lovers.
  4. Jokevalues
    Jokevalues New Member
    Oct 27, 2014
    27
    2006 VW Jetta TDI
    Jersey Shore
  5. xeno555
    xeno555 Well-Known Member
    Dec 12, 2011
    1,684
    2012 TDI Tech Package 6mt
    Mile High
    Top two reasons for poor winter performance on TDI:
    1. Coolder temperature:
    Denser air, needing more exhaust gas/energy to chop up and compress. - Worse gas mileage - If your very attentive, blocking inter-cooler will help a bit.
    Cooler temps making engine cooling systems too efficient. - Long warmup times (do not warm up your car by letting it idle (never warms up)). If your very attentive, blocking radiator will help.
    Cold air intake may decrease mileage even more in winter?
    Other things that help:
    Garage.
    Block heater.
    Instant frost heater.
    Heated seats.
    Heated steering wheel.
    Heated shifter.
    Heated mirrors/washer.
    2. Anti gelling additive added to fuel, making it contain less stored energy. (no getting around this). - Worse gas mileage.
  6. chittychittybangbang
    23,902
    Those will work but I just removed the grille, stuck some pre-slit pipe insulation behind the grille slats, and zip tied one/slat. They didn't move at all anyways. I bought the pipe insulation at a discount store for $1/each.
  7. Sparkn
    Sparkn Member
    Mar 27, 2014
    211
    2014 Jetta TDI
    Illinois
    There should be a prominent cold weather sticky. This question comes up so much it'd be nice for peeps to find a one stop shop for information. You know, something with links to Frost Heater, IDParts, foam insulation videos, etc.
    I have a 40 mile one way commute so I get to see the full range of warmup and steady max mileage at temp. All cars, diesel or gas, will get lower fuel mileage in the winter. But, of course, diesels are hit harder due to much less waste heat.
    Most already know this, but I'll explain it as I know it. A gasoline engine mixes air and fuel, compresses it and then ignites it. The leaner that mix is, the hotter it can be. Think of it like a bunsen burner or a gas stove. Without enough air the flame turns yellow and cold. Add air and it turns blue and hot. A gas engine is no different in this respect and as such is much hotter than a diesel and can weather better.
    The diesel, on the other hand, doesn't toss any fuel into the mix until it's ready for combustion. It's more like lighting a lighter in a compressed air space and it's also the reason the fuel pressure is a thousand times higher than gasoline non direct injection engines.
    All engines, regardless of fuel, suffer from two major obstacles to overcome. 1. Get heat into the engine. 2. Keep heat in the engine. Manufacturers do things like size the radiator, select thermostat, control cold air intake, etc. but the manufacturer rarely goes the extra mile required to see major improvement in these areas (this is changing in the current marketplace) due to costs and consumer demand.
    The biggest recent change (driven by consumer demand) is the active shutter. Cardboard and ty-strap uses have known for years that lower heat loss at the radiator helps keep both the engine and the operator toasty and warm with the lesser known benefit of slightly improved aerodynamics. Now, as active shutters gain popularity, this temperature can be regulated year round. Effectively, this regulates radiator capacity, which is way too high in the winter. A thermostat may be able to regulate flow, but it can't control how cold the water is returning to the engine. You would need a tempering gate to achieve this, or, just keep the water from getting too cold in the first place. Ironically, the active shutter is designed as an aerodynamic tool, but in the winter, has more value throttling cooling capacity in a diesel engine.
    I haven't seen active shutters available yet as an aftermarket, so, what am I to do? First, we can get heat into the engine. Some solutions for that are:
    Park in a heated garage.
    Install a Frost Heater or similar radiator water heater.
    Both good starts and allow the engine to heat up quicker by starting at a higher temperature to begin with. The heated garage has other benefits, too, but the cost is hardly justifiable to someone saving fuel costs. Neither are usually available away from home.
    Items that keep the heat in are available all the time and include:
    Foam covers for the grill.
    Pre-made covers for the grill (such as available from IDParts)
    Use air recirc in the cabin as much as possible
    Grill covers act like active shutters...without the active part. Also, reducing the capacity of your radiator means less cooling is available when the outside temperature goes up. This can be an issue in the Spring when temperatures can swing wildly from day to day. If you are lucky enough to be exposed to the cost cutting practices at VW you may not even have a temp gauge in the cabin to even see you have a problem developing. Some prudence here goes a long way. You may even decide you want a temp reading available. The aftermarket supplies fine solutions.
    This is my first year driving a diesel car but is not my entry point for dealing with diesels. I drove this winter with no modifications to see how well VW manages this through engineering and to see what would have the best bang for the buck for me. For me, I have complete confidence that installing a grill cover, as has been done since the first diesel met it's first winter, is a great first step with a Frost Heater being a close second. Cars in more extreme conditions where just starting the car can be a problem will probably prioritize differently and utilize other solutions in addition such as battery blankets, additional batteries, relocated batteries, etc.
    Well, there's my viewpoint. Feel free to trash it or correct me as necessary. I'm not perfect. This is just my view into the world. I know I repeated a lot of what others have said, but only because I'm agreeing with you.
  8. Ol'Rattler
    Ol'Rattler Well-Known Member
    Apr 24, 2011
    838
    06 TDI Jetta
    Marysvile, WA.
    No, not really. A diesel needs to be under load to heat up.
    xxlonghaulerxx and Sparkn like this.
  9. ALT 10000'
    ALT 10000' New Member
    Apr 14, 2014
    21
    VW, Jetta,'04 BEW
    Colorado
    Chipped
    Buy and install a skid plate so you are able to start a fire under the engine where the oil pan is! Let the fire burn as you watch it. Don't let the flames burn anything. Yeah, this may take some effort and make you colder then a witches tity while watching the flames. But my gramps is always right!
  10. Sparkn
    Sparkn Member
    Mar 27, 2014
    211
    2014 Jetta TDI
    Illinois
    Or possibly a Frost Heater, maybe?
  11. ALT 10000'
    Apr 14, 2014
    21
    VW, Jetta,'04 BEW
    Colorado
    Chipped
    This may seem crazy! If you have heated seats, rear window defrost and mirrors, turn all those on. Also here is the important one wear an winter jacket and turn the A/C on. These loads will put a larger load on the engine and the heating up curve will be reduced.
  12. Ol'Rattler
    Apr 24, 2011
    838
    06 TDI Jetta
    Marysvile, WA.
    Correct, except the A/C is always on but not under load with the switch off. It is a variable displacement pump that turns but doesn't displace anything when switched off.
    With the switch on in cold weather there will not be much if any additional load however, turning on the A/C might make the car defrost quicker.
  13. Sparkn
    Sparkn Member
    Mar 27, 2014
    211
    2014 Jetta TDI
    Illinois
    Turn on all that if you like, but the extra load will still only be about 1 horsepower per 450 watts or so (taking efficiency into account). This has potential to help, but should be considered complementary to a more effective scheme like blocking the radiator. In the end, the clear windows and warm tush are of more value to you than the load assist to the engine.
