VW Tiguan - Exhaust Gas Temp Fault
Discussion in 'General Diesel Discussion' started by TDISportAaron, Mar 1, 2017.
  1. TDISportAaron
    TDISportAaron New Member
    Jan 10, 2017
    13
    2008 VW Tiguan 2.0 TDI 170 SE
    UK
    Plugged my VCDS into the car today to see what faults were awaiting me to find these:
    Address 01: Engine (CBB) Labels: 03L-906-022-CBA.clb
    Part No SW: 03L 906 022 HM HW: 03L 906 022 G
    Component: R4 2,0L EDC G000SG 3074
    Revision: --H01--- Serial number: VWX7Z0H43NS0KP
    Coding: 0000172
    Shop #: WSC 00434 210 71539
    VCID: 77A8E13D63CE609F1C3-8022
    2 Faults Found:
    008320 - Exhaust Gas Temp Bank 1 Sensor 1 (G235)
    P2080 - 000 - Implausible Signal
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 184869 km
    Time Indication: 0
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Voltage: 11.32 V
    Temperature: 3.6°C
    Temperature: 282.0°C
    Temperature: 0.0°C
    Temperature: 0.0°C
    001348 - Sensor 1 for Exhaust Temp Bank 1 (G235)
    P0544 - 000 - Circuit Malfunction - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 255
    Mileage: 184911 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 12:16:45
    Freeze Frame:
    RPM: 966 /min
    Speed: 3.0 km/h
    Voltage: 14.14 V
    Temperature: 53.1°C
    Temperature: 930.0°C
    Temperature: 192.0°C
    Temperature: 174.0°C
    Readiness: 0 0 0 0 0
    Any ideas what the issue could be? What I can do to start to diagnose/fix?
    The car was in at the garage last week to have the "coolant pump 2" replaced and this is the first scan since then.
