VCDS Readings, is my PS elements ok?
Discussion in 'Ross Tech VCDS forum' started by Troelssk, Jul 8, 2016.
  1. Troelssk
    Troelssk New Member
    Jul 12, 2015
    5
    VW, touran, 2007
    Denmark
    hi
    As the topic, is my injectors going bad?
    I have a studder at around the 1800-2200 rpm range. I took it to the stealer shop and they told me that i might have an injector starting to go bad.
    Here is the readings from vcds block 013:
    Cyl 1: -0.87
    Cyl 2:-0.14
    Cyl 3:0.35
    Cyl 4:0,68
  2. Seatman
    Seatman Well-Known Member
    Jul 9, 2010
    5,779
    Scotland
    PP764's, turbo and mapping
    Look fine I think, #1 is maybe slightly out but not bad, the injector wiring loom often goes bad before the injectors themselves too. Sometimes just cleaning the plugs makes a difference.
    Another thing could be the lift pump in the tank or even just replacing the fuel filter can solve these things.
