VCDS group 13&23 interpreting help
Discussion in 'Ross Tech VCDS forum' started by ramman, Nov 16, 2015.
  1. ramman
    ramman New Member
    Dec 9, 2010
    15
    VW Jetta 2000
    Can someone help me interpret these VCDS group 13 &23 numbers for my bad miss problem on 06 PD engine.
    group 13 2.99 mg/str 2.99mg/str -301mg/str =301mg/str
    group 23 -128.0 -64.0 -61.0 -54.0
    I recently bought 06 Jetta 5 speed with a distinct 3 cylinder idle, above 2500 rpm it pulls like my old tuned ALH, check'd engine cam today and I see no issue, not sharp on edges lobes look good unless I missed something.
    Cold compression test revealed cyl #1 -300 cyl#2-300 cyl #3-290 cyl #4-300.
    #1 #2 injectors show evidence of Plier marks on the I assume solenoid, large nut shaped part on front of it. Unplugged #1 then #2 expecting to determine the missing Cyl like an old Gas engine but both affected it ???
    I didn't try 3 &4 assuming the Cyl#1 misfire code indicated the problem cyl.
    new to the PD thing, three ALH cars in the past 10 years. Any help appreciated.
