VCDS Engine control module adaptation
Discussion in 'Ross Tech VCDS forum' started by Stipe TDI, Dec 31, 2015.
  1. Stipe TDI
    Stipe TDI New Member
    Mar 11, 2015
    19
    VW Golf 1K 2007
    Herzegovina
    Dear friends,
    I want to run my TDi better so I want to explore this control module adaptation. I log in with 12233 and gets some incomprehensible channels.
    Please look photos
    https://drive.google.com/folderview?...3M&usp=sharing
    So at channel 6 i adjust idle rpm, from 820 I decrease them on 800
    but I want to know what
    channel / value
    16 / 100
    17 / 300
    18 / 300
    19 / 0
    20 / 200
    21 / 200
    22 / 0 means?
    The module is
    Part No SW: 03G 906 021 KH HW: 03G 906 021 AN
    Component: R4 1,9L EDC G000SG 9245
    23,816
    I'm not sure but usually that means you cannot change them.
  3. Stipe TDI
    Mar 11, 2015
    19
    VW Golf 1K 2007
    Herzegovina
    I can change them.
  4. Alex_r
    Alex_r New Member
    Sep 29, 2013
    11
    VW Golf Mk5 1.9 BXE
    Belarus
    No cat
    Sorry but why you've lowered idle rpms? Because of mpg? Did you check oil pressure at idle after this mod? PD engines are well known for their poor camshaft lubrication...
  5. Stipe TDI
    Mar 11, 2015
    19
    VW Golf 1K 2007
    Herzegovina
    I lowered RPM because I fell that then engine is a little bit vibrating at factory value (840 rpm). So at 800 it is also a quieter. I did not lower it because of MPG. I did not measure oil pressure, I do not think that this little change will affect it, what you think? The problems with cams are because long life oil services and inadequate oil.
    I see that you own same engine. My has 270tkm on clock and still counting with average consumption of 4,8 l/100 km in last 40000 km. What about you? Are you satisfied with it?
  6. Alex_r
    Alex_r New Member
    Sep 29, 2013
    11
    VW Golf Mk5 1.9 BXE
    Belarus
    No cat
    Mine has 220k.
    Returns 6.3 l/100km urban; about 4.7 l/100 km highway. Did you have sporadic vibration at idle? Mine wobbles a bit, I've replaced turbo, flywheel, camshaft+lifters, injector seals, cleaned EGR - and still have shaky idle...
  7. Peca
    Peca Member
    Jun 12, 2013
    96
    Passat b5, 2000, 85 KW
    Pale, Sarajevo BIH
    Gdje si zemljak?
  8. xeno555
    xeno555 Well-Known Member
    Dec 12, 2011
    1,661
    2012 TDI Tech Package 6mt
    Mile High
    Nit
  9. Stipe TDI
    Mar 11, 2015
    19
    VW Golf 1K 2007
    Herzegovina
    Hmmm, maybe very rare sporadic idle, it is difficult to notice. What is your injection timing? I think to try diesel purge, although injection deviation is max 0,5 mg/str, but I have read that this resolve loud engine noise and gives steady idle.
    Evo zemljo, šta ima, kako ti? Čim se baviš?
    What do you want to say?
  10. Peca
    Peca Member
    Jun 12, 2013
    96
    Pale, Sarajevo BIH
    Evo po malo radim oko mehanike pa povremeno pišem po forumu kad imam vremena, ponešto i naučim uvijek ima nešto novo da se sazna. Šta se dešava sa kolima?
  11. xeno555
    Dec 12, 2011
    1,661
    Mile High
    Exactly...
  12. Stipe TDI
    Mar 11, 2015
    19
    VW Golf 1K 2007
    Herzegovina
    can you be more specific?
  13. xeno555
    Dec 12, 2011
    1,661
    Mile High
    It is not 'exactly' easy to help, when another language is used.
  14. Stipe TDI
    Mar 11, 2015
    19
    VW Golf 1K 2007
    Herzegovina
    Sometimes when speaks same language it is difficult to understand, like when you write : " Nit "
  15. Keithuk
    6,850
    I take you don't have a genuine VCDS cable? If you do then register it online VCDS Dongle Registration then you can join the Ross-Tech forum. Then you can ask this question on there with a full AutoScan.
    If you don't have a genuine cable then you can't run the latest version. VCDS Release 15.7.3
    I moved this thread to the Ross-Tech section as its related.
  16. xeno555
    Dec 12, 2011
    1,661
    Mile High
    Which brings me to my point, EXACTLY.
    Anyhow, when a option in VCDS says something the the effect of "undocumented channel" means just that. Changing values in VCDS can be dangerous. This is more so, if your changing unknown random values.
    For example on the forum, someone messing around and changed their "max MPH limiter" to 60 and seee what it does.
    Guess what, you can only change that number to a lower number and can't change it higher. It is a permanent change. It will require a reflash from dealership or replacement. Guess what, now he is driving under 60MPH.
  17. Stipe TDI
    Mar 11, 2015
    19
    VW Golf 1K 2007
    Herzegovina
    No, I do not have genuine cable. This is because I do not have workshop, just sometimes explore my car. Anyway, for our country, the price is too high, maybe we can compare monthly revenue here and rest of word. But I hope one day I ll buy it. Sorry Rosstech team.
    It seems I had luck. I change it, and nothing special happens. Also I check the values can roll back. So, maybe one day I fill find out what this changes. Maybe if some one has answer, then please write it /copy here. I can t register on rosstech site.
  18. xeno555
    Dec 12, 2011
    1,661
    Mile High
    VW doesn't just put thing just because. That being said, you changed something, you just don't know the effect yet, and may forget when they do arise.
    Rereading your post, are you asking if that portion that was unknown is now labled correctly in the newest build?
  19. Stipe TDI
    Mar 11, 2015
    19
    VW Golf 1K 2007
    Herzegovina
    You have right. I am beginner. It was not smart to do so.
    Maybe new version has describe it? I notice maybe better starting and lower fuel consumption, but it is hard to say. Maybe I need more time or more knowledge about this.
    Alex, can you scan/write your values for this control module and channels?
  20. xeno555
    Dec 12, 2011
    1,661
    Mile High
    Only way I could find it is to scan like module with newest version. Euro models are different. Look through your logs, maybe you saved the original value?
