VAG Engine & Transmission Codes
Discussion in 'General Diesel Discussion' started by Keithuk, Jan 14, 2014.
  1. jonlowe
    jonlowe Member
    Aug 9, 2011
    18
    2005 Passat GLS Variant
    Ok, I've tried on three different computers, 3 different browsers, including Firefox, and neither the application nor the PDF files will download from Rapidshare. I even tried an Android phone with two different browsers. In every case, I get the same "File not found" error code.
    To check further, I just downloaded your EOBDII codes, Timing belt app, and OBD 2 Lookup app just fine in my various browsers. I think there is a problem with the links in the text files you have in this thread. Why it is just these two links, and not any of the other links, I have no clue. I did note that some of your files in the other threads are zips, and others are rars, but that doesn't seem to make any real difference.
    Hope you can figure this out. I find your apps very useful.
  2. Keithuk
    7,235
    Well I pasted the link from the txt file into IE11 and FireFox and they both downloaded. I've just copied and pasted it in again and it downloads.
    If you PM me your email address I will post you a personal copy?
  3. jonlowe
    jonlowe Member
    Aug 9, 2011
    18
    Will do.
    Thanks!
  4. Keithuk
    7,235
    I did a test email to myself because email attachments do depend on the size (1,251 KB) and it came back no problem and the app worked. I sent Jon an email (see PM Jon) with the new app and it came back with an error as the attachment contains files that could damage a computer.
    I've updated the download link in post #1 as the new version allows you to save all 8 pdf files (from this months ETKA updates) or each one individually to the app folder. I checked the download link and it works and the app runs.
  5. Keithuk
    7,235
    Ok I've checked all info and corrected typo's on the dates as it easy to copy and paste from the pdf file.
    ETKA shows 2015 Golf Sportsvan which the pdf shows 02/14-
    I've added the new 8 pdf files to the app not the old ones I've uploaded in here.
    It appears that with every ETKA monthly update there are new dates added so it will be an on going task to keep my app up to date.
    I've downloaded this new update and it works like every app I've added to RapidShare.
  6. Keithuk
    7,235
    Ok RapidShare used to be free as of 1st July 2014 they are now charging € 49.99 per month so they can stuff that as I'm still not working. A friend on another forum has started using https://mega.co.nz/ so I'm trying that new site out which works pretty good.
    I installed ETKA June updates so I've saved all PDF files and I've uploaded them to mega if you want to try them out as. The disadvantage of mega is you can't see how many times an app has been downloaded so I just have to count the number of times the txt file has been downloaded. Its much easier to use my app.
    New link in post #12.
    All my uploads will be to mega from now on even though the old RapidShare files still work.
    There is a new link to my app in post #1.
  7. Keithuk
    7,235
    Ok I've updated ETKA and I've added all new codes as listed in post #1.
    I've also added the new PDF files in post #12.
  8. Keithuk
    7,235
    OK I've made an update from Nov 2014 ETKA. New main update is in post #1. I've updated the PDF files in that post if you don't want to use my app.
    jonlowe likes this.
  9. jonlowe
    jonlowe Member
    Aug 9, 2011
    18
    Keith,
    Thanks a lot for continuing to do this. I have found this to be extremely useful, especially as I consider doing a TDI swap into an Audi. Please keep up the good work.
    Jon
  10. Keithuk
    7,235
    New updates posted in #1.
    Engines 6,308
    AUDI 1,467
    SEAT 696
    SKODA 553
    VW 3,592
    Transmissions 13,033
    AUDI 3,903
    SEAT 1,338
    SKODA 1,221
    VW 6,571
  11. Keithuk
    7,235
    I haven't updated this app for a few months so I've finally got around to updating it.
    Engines 6,644
    AUDI 1,526
    SEAT 731
    SKODA 596
    VW 3,791
    Transmissions 13,449
    AUDI 3,903
    SEAT 1,422
    SKODA 1,331
    VW 6,793
    There are new engine and transmission codes.
    CBZB in all ranges
    CJSC PASSAT, SKODA SUPERB
    CJXA PASSAT, SEAT LEON, SKODA SUPERB
    CUPA PASSAT, SEAT LEON
    CUVC, CC
    CZDC SCIROCCO
    CZDD GOLF VARIANT
    CZTA JETTA NORTH AMERICAN REGION (NAR)
    CBGA PASSAT
    CNCE AUDI A5 CABRIOLET SPORTBACK COUPE QUATTRO
    CRTC AUDI Q7
    CTBD AUDI A8
    CTGF AUDI A8
    CUEA AUDI Q7
    CVMD AUDI Q7
    CYRB AUDI VORSPANNMODELL
    CZGB AUDI RS3 SPORTBACK
    CZZA AUDI Q7
    CZZB AUDI Q7
    CVKB AUDI A4
    CVNA AUDI A4
    CYMC AUDI A4
    CYRC AUDI A4
    CZHA AUDI A4
    CZVB AUDI A6, A7 SPORTBACK TDI-CR
    CZVD AUDI A6, A7 SPORTBACK TDI-CR
    CZVE AUDI A6, A7 SPORTBACK TDI-CR
    CZVF AUDI A7 SPORTBACK
    DBBA AUDI Q3
    DCZA PASSAT, SKODA SUPERB
    DFCA PASSAT, SKODA SUPERB
    DFEA PASSAT, SKODA SUPERB
    DEHA AUDI Q5
    DEJB AUDI A3 TDI-CR
    DESA AUDI A4
    DETA AUDI A4
    DEUA AUDI A4
    DEUB AUDI A4
    DFTC AUDI Q3
    DFSB SKODA YETI
    CUGA SKODA SUPERB PLUS STYLE
    CUUC CADDY
    CUUD CADDY
    CUUE CADDY
    CUUF CADDY
    CUVC TIGUAN, CC
    CUVE TIGUAN
    CXEB CALIFORNIA CAMPMOBIL CARAVELLE TRANSPORTER
    CXFA CALIFORNIA CARAVELLE TRANSPORTER
    CXGA CXGB CARAVELLE TRANSPORTER
    CXHA CARAVELLE TRANSPORTER
    CYVC CADDY
    CRGA GOLF GTD
    CRLD GOLF
    CSDA TRANSPORTER
    CSLC CRAFTER LT
    CZCB CADDY
    CZDB TIGUAN
    CZTA JETTA
    DEBA JETTA
    DELA JETTA
    I won't bother posting the new app as no one is interested in the old app.
    Vwman2015 likes this.
  12. 993er
    993er Member
    Oct 18, 2013
    51
    2013 VW Jetta TDI 6 Speed
    North America
    I keep my vehicles stock and bling-free.
    Hi Keith,
    I believe my code for my North American & Canadian Jetta is CJAA which is missing in your list.
    By the way, what does ETKA stand for? I also saw this with respect to BMW parts and parts pricing.
  13. Keithuk
    7,235
    Its in my new app but no one had requested this one.
    CJAA 140PS 07/09-10/10 Jetta, 06/09-07/14 Jetta Canada USA, 07/09-07/13 Golf, 05/11-05/13 Golf NORTH AMERICAN REGION (NAR), 04/11- New Beetle.
    ETKA - Elektronischer Teilekatalog
    https://en.wikipedia.org/wiki/ETKA
  14. Keithuk
    7,235
    As you can see from post #1 only 15 users have downloaded VAG_Engine_&_Transmission_Codes_14-05-2015.txt and 32 users have downloaded VAG_Engine_&_Transmission_Codes_PDF_14-05-2015.txt. So no one is really interested in may app.
    I update this app every month when I install the new ETKA updates. As you can see from the file date 14-05-2015 I haven't posted a new update because users don't seem that interested in my app. The new ETKA 7.5 Plus shows details in a slightly different format, it now shows the date with the full year and model variants in the same code number.
    If you want to print all data that will take a lot of paper. If you print the Audi Engine PDF file that's 85 pages, VW Engine PDF file that's 92 pages, Seat Engine PDF file 8 pages, Skoda Engine PDF 5 pages. The Audi Transmission 232 pages, Seat Transmission 23 pages, Skoda Transmission 20 pages, VW Transmission 321 pages.
    With the new app you can right-click on the Engine data and Transmission data and copy any selected data to the Window Clipboard and paste that into a forum or text file.
    The PDF file shows Mounting Time: which to me is the wrong terminology Mounting Time means time hours/minutes/seconds so I've change that to Date(s) Used. The new PDF shows all dates in the full year format so I've changed all the dates.
    e.g.
    Manufacturer: VW, Date(s) Used: 05/2000-07/2001, Model: Jetta Variant, Engine Code: AUY, 85Kw, 115PS, 1.9 Ltr, 4 Cyls, Remarks: Turbocharged Direct Injection Pumpe Düse (TDI-PD)
    Manufacturer: Audi, Date(s) Used: 05/2015-08/2016, Model: Audi A3/S3 Sportback/Limousine/Quattro, Engine Code: CXXB, 81Kw, 110PS, 1.6 Ltr, 4 Cyls, Remarks: Turbocharged Direct Injection Common Rail (TDI-CR)
    Manufacturer: VW, Date(s) Used: 06/2015-, Model: Beetle, Engine Code: DELA, 110Kw, 150PS, 2.0 Ltr, 4 Cyls, Remarks: North American Region (NAR): Turbocharged Direct Injection Common Rail (TDI-CR)
    Manufacturer: VW, Date(s) Used: 07/2010-07/2014, Model: Jetta, Engine Code: CJAA, 103Kw, 140PS, 2.0 Ltr, 4 Cyls, Remarks: Canada ("CDN"), USA ("USA"): ComfortLine, SportLine, Turbocharged Direct Injection Common Rail (TDI-CR)
    If someone wants the new PDF files post a comment and I'll post a new link as of 01/12 2016.
    There are plenty of new engine codes for new models, this is just VW.
    VW DFEB Touran TDI-CR
    VW DFGB Touran TDI-CR
    VW DFGA Touran TDI-CR
    VW DGDA Touran TDI-CR
    VW CDBC Tiguan TDI-CR
    VW CUUA Tiguan TDI-CR
    VW CHHB Tiguan TFSI
    VW CSTA Bora C-Tech The Bora is made in China by the FAW-Volkswagen joint venture
    VW CZCA Tiguan TSI
    VW CZPA Tiguan TFSI
    VW CZEA Tiguan TSI
    VW DFGA Tiguan TDI-CR
    VW DFGC Tiguan TDI-CR
    VW DFHA Tiguan TDI-CR
    VW DGDB Tiguan TDI-CR
    VW CRFD Tiguan TDI-CR
    VW CRGB Tiguan TDI-CR
    VW DBGC Tiguan TDI-CR
    VW CYKC Tiguan TDI-CR
    VW CCLA Passat 4Motion/Variant/CC TDI-CR
    VW CDGB Passat TDI-CR
    VW CDGB Passat Variant TDI-CR
    VW DGMA Jetta TDI-CR
    VW DDXA Amarok V6 TDI-CR
    VW DDXB Amarok V6 TDI-CR
    VW DDXC Amarok V6 TDI-CR
    VW CREB Phideon 3.0 FSI
    VW CUHA Phideon 3.0 FSI
    VW CYYA Phideon 3.0 FSI
    VW DBGB Passat TDI-CR
    VW DCYA Golf Sportsvan TSI
    VW DCYB Golf Sportsvan TSI
    VW DDYA Golf Sportsvan TDI-CR
    VW DDYB Golf Sportsvan TDI-CR
    Magnus likes this.
  15. Keithuk
    7,235
    This thread was made a couple of years ago in members only section. There have been only a few downloads of my old app so I've moved it to General Discussion.
    The new app has a different feature as you can copy any line on code to the Windows clipboard rather that printing out hundreds of pages so you can paste to a file or forum. You can also save the newest 8 PDF files to browse.
    The new one has:
    Engines 6,973
    AUDI 1,820
    SEAT 682
    SKODA 470
    VW 4.001
    Transmissions 15.008
    AUDI 4,073
    SEAT 1,543
    SKODA 1,432
    VW 7,960
    I've cut down on model abbreviations in the new version.
    If anyone wants the newer version let me know and I'll upload the new link? Or if you just want the PDF files which don't list correctly, let me know?
  16. Keithuk
    7,235
    Ok for those users that don't want to download and use my app I've uploaded all 8 PDF files from 05/2017 ETKA. Obviously the new PDF files don't have the older vehicles. May app has all of them from the beginning.
    The new download link is in post #1.
    The new VAG Engine & Transmission Codes app you can right-click on any line shown and copy the details shown to the Windows clipboard and paste it into a file or forum.
    If anyone wants to use my new app which is better than the old VAG Engine & Transmission Codes 14-05-2015 posted in here, let me know?
    Lowlander and Vdubcaddy like this.
  17. Lowlander
    Lowlander New Member
    Nov 13, 2017
    A4
    Here
    i like to use the new software as i use it a few times a week
    great work
  18. Keithuk
    7,235
    Car: A4 but what year and engine type. Location: Here isn't very informative, please change this? ;)
    This isn't the new software this is the old one as post #1 says. This is posted on a few forums but no one has asked for the new version.
  19. edy
    edy New Member
    Nov 23, 2017
    Skoda Superb 3t427c . engine:cbbb 170 cp dsg ltd
    Romania
    Hy Keithuk ! I can say that your app is really helpful. I would like to thank you beacause it helped me a lot (this forum too). I am not a mechanic, but using your info's I figured out what type of gearbox fits to my car (because no one wanted to say and it was very difficult to find the right gearbox). Thanks to you it was very easy. Keep working.
  20. Keithuk
    7,235
    As I said in your email about the new app, why is you email name eBay when you edy on here?
    You couldn't remember where you downloaded it from so I gave you a few links. Is that why you've joined this forum?
