Turning off Seat belt warning in VCDS
Discussion in 'Ross Tech VCDS forum' started by TDI_Brad, Sep 5, 2012.
  1. TDI_Brad
    TDI_Brad Member
    Oct 23, 2011
    208
    2012 Passat TDI SEL
    Cool Stuff
    I was playing in VCDS last night and turned off my seat belt warning. Its under instruments address then adaptations. There is a channel for seatbelt warning. Change that from version 2 to 3. This changes the chime you hear when starting the car and the seatbelt light comes on briefly and then goes off with seatbelt not buckled. I don't know if anyone else has posted or discovered this so I thought I would share but you should still wear your seatbelt.
  2. Keithuk
    6,771
    I turned my seat belt warning and chime off http://www.myturbodiesel.com/forum/f24/my-vcds-tweaks-9156/.
    To do this it uses Long Coding so what you changed should be logged in C:\Ross-Tech\VCDS\Debug\CodingLog.TXT.
  3. TDI_Brad
    TDI_Brad Member
    Oct 23, 2011
    208
    2012 Passat TDI SEL
    Cool Stuff
    I didn't even realize there a VCDS section in this forum because I always go the B7 section through my bookmarks link. Thanks Keith I'll have to see what other tweaks I can find in here.
  4. tom308
    tom308 New Member
    Sep 5, 2012
    2006 jetta
  5. Keithuk
    6,771
    I have a user on another forum that wants to enable the seatbelt chime on his 2006 EOS 2.0 FSI. I showed him what I did I did with mine. He says he doesn't have Long Coding in his system. As anyone tried this on there 2006 models?
    Enable Seat Belt Chime
    I searched for this and found a video for the same procedure on a Mk3 Scirocco.
