Turbo problems
Discussion in 'General Diesel Discussion' started by Tombobillabongo, Jun 23, 2017.
  1. Tombobillabongo
    Tombobillabongo New Member
    Jun 23, 2017
    4
    Seat leon fr mk1 2006
    Beds, UK
    Hi,
    Thanks for your help in advance!
    I'm getting some noises from my turbo on my pd150 ARL engine with standard garret turbo... I can hear the siren like noise but also a bit of a metallic version of the normal boosting sound. I'm guessing worn bearing and new turbo needed? Anyone have an idea of what's gone wrong here? I've attached this film - sorry about the boring visuals - this is just stationary revving:
    I have recently taken the turbo off, taken it apart and cleaned the VNT mechanism because the vanes were sticking (got an over boosting fault code) . It's boosting ok now but sounds like this.
    When it was apart I noticed about half a millimetre of play in the compressor wheel. I also added a forge red turbo pipe - could this be changing the sound?
    Any help would be much appreciated!
    Thanks!
  2. crsmp5
    crsmp5 Well-Known Member
    Feb 14, 2012
    1,504
    85 kubvan
    you know those are very sensitive to any weight changes right?? if you have ever seen a pro balance a turbo... you would never try taking one apart...
  3. Tombobillabongo
    Jun 23, 2017
    4
    Beds, UK
  4. crsmp5
    Feb 14, 2012
    1,504
    85 kubvan
    again... if you have ever seen the work a pro goes thru to balance one... you would never attempt it.. as there is no way you can do this with out proper equipment... that thing buzzes along at many rpm...
  5. EKAN
    EKAN New Member
    Oct 29, 2016
    29
    Passat 1,9 tdi 1999
    Jonkoping
    You don't have to balance the turbo if you just clean the vanes.
    But I agree that you should know what you are doing when you work with a turbo.
