Transmission Info & Procedure - Help!
Discussion in 'VW Mk6 Golf, Jetta, Beetle, Sportwagen TDI forum' started by CoalRoller, Dec 26, 2016.
  1. CoalRoller
    CoalRoller New Member
    Sep 20, 2016
    2010 VW JSW TDI
    Social Circle, GA
    Hello everybody. I had a great experience getting my timing belt done last month by simply lurking and feeding off the resources here and at tdiclub.com. However, I've found that research on transmission removal is limited and questionable.
    Here's the rundown... I have a 2010 Jetta Sportwagen TDI (obviously) with a manual 6 speed tranny . Last week, my clutch pedal lost pressure and collapsed to the floorboard. When I try to pump the clutch, brake fluid flows freely from the transmission. You can see it here - https://youtu.be/_1Ccv4IW4WI. I believe the slave cylinder is kaput! So I'm trying to look up info, but I was surprised to find that there wasn't a procedure specific to my car.
    I've some questions:
    What is it? Do I have a MKV or MKVI?! I thought it was a MKVI...
    What tranny do I have? (Like how I have a CJAA engine)
    Does http://www.myturbodiesel.com/wiki/ma...-vw-jetta-tdi/ apply to my vehicle with a 6 speed?
    Very grateful for any input and help! [​IMG]
  2. xeno555
    xeno555 Well-Known Member
    Dec 12, 2011
    1,684
    2012 TDI Tech Package 6mt
    Mile High
    1. Mk6
    2008–2013(EU)
    2009–2014(US)
    2. MT6
    3. Yes for your extent. However slave cylinder is mounted to the outside of transaxle, and does not require pulling engine or transmission.
