Touareg 3.0 v6 HDi slow to start when cold
Discussion in 'Audi Q5, Q7, Touareg TDI, Porsche Cayenne forum' started by Whoson, Mar 27, 2017.
  1. Whoson
    Whoson New Member
    Mar 23, 2017
    VW Touareg 3.0tdi 2006
    Australia
    Greetings all> I'm new to posting into this group, so apologies if this is in the wrong spot. I have had a good look around what is s great looking forum, and can't find similar issues so here goes here.
    I'm having a frustrating time with slow starts, and have done for some time. The touareg will start, but only after 10 - 20 seconds turning over. Then for the rest of the day will start normally. I live in Ballarat Victoria (Aus) summertime now, and a generally temperate climate.
    Here is the last Ross Tech scan, engine running, (current mileage actually 161194??) after which I cleared the fault codes, and re ran the scan with no glowplug faults showing. The Central electrics faults also cleared - probably they showed up on one of the 20 second turnover starts?? As the engine was now warm, probably the computer said no need to even try turning glowplugs on?
    I am thinking (and have ordered) a replacement Glowplug control relay, what do others think?
    Monday,27,March,2017,17:27:13:14409
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
    VCDS Version: 17.1.3.0
    Data version: 20170220 DS267.3
    www.Ross-Tech.com
    VIN: WVGZZZ7LZ7D014189 License Plate:
    Mileage: 161190km-100158mi Repair Order:
    Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
    Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
    37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
    VIN: WVGZZZ7LZ7D014189 Mileage: 161190km-100158miles
    Address 01: Engine Labels: 059-907-401-ASB.clb
    Part No SW: 7L0 907 401 B HW:
    Component: 3.0L V6TDI G000AG 0090
    Revision: --H03--- Serial number: VWZ3Z0F1509001
    Coding: 0011779
    Shop #: WSC 30023 959 91515
    VCID: 2A5BBABC86C7601197-5124
    1 Fault Found:
    005676 - Glowplug Control Module; Supply Voltage
    P162C - 000 - Open Circuit on Load Side
    Freeze Frame:
    Fault Status: 01110000
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 161136 km
    Time Indication: 0
    Freeze Frame:
    RPM: 126 /min
    Torque: 214.5 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 9.88 V
    Duty Cycle: 95.5 %
    Temperature: 18.9°C
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans Labels: 09D-927-750.lbl
    Part No: 09D 927 750 EB
    Component: AL 750 6A 0879
    Coding: 0004200
    Shop #: WSC 31414 000 00000
    VCID: 72EB62DC6E9768D1EF-5140
    No fault code found.
    Address 03: ABS Brakes Labels: 7L0-907-379-MK25.lbl
    Part No: 7L0 907 379 G
    Component: ESP ALLRAD MK25 0203
    Coding: 0014338
    VCID: 3D7181E06749E7A9C2-5140
    Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
    Part No SW: 3D0 909 139 HW: 5WK 484 94
    Component: Kessy 6700
    Revision: 67006015 Serial number: VWZ3Z0F1509001
    Coding: 0000232
    VCID: 66C30E8C525F847173-5140
    Subsystem 1 - Part No: XXXXXXXXXXX
    Component: ELV XXXX
    Address 08: Auto HVAC Labels: 7L6-907-040.clb
    Part No: 7L6 907 040 T
    Component: CLIMAtronic R/L 4222
    Coding: 0020520
    VCID: 4189FD101BB18349A6-5140
    2 Faults Found:
    02508 - Temperature Sensor for Refrigerant (G454)
    010 - Open or Short to Plus
    00445 - Loss of Refrigerant
    015 - Cannot Be Tested at this Time
    Address 09: Cent. Elect. Labels: 7Lx-937-049-V1.clb
    Part No: 7L6 937 049 M
    Component: 3003
    Coding: 0098428
    VCID: 4683EE0C329FA47193-5140
    2 Faults Found:
    01117 - Generator Terminal DF Load Signal
    008 - Implausible Signal
    00907 - Intervention load Management
    000 - -
    Address 15: Airbags Labels: 3D0-909-601.lbl
    Part No: 3D0 909 601 F
    Component: 0F Airbag 8.4E+ H11 1152
    Coding: 0012358
    VCID: 26434E8C92DF4471B3-5140
    Address 16: Steering wheel Labels: 7L6-953-549.lbl
    Part No: 7L6 953 549 H
    Component: Lenksäulenmodul 3401
    Coding: 0010031
    VCID: 4487F40404A396618D-5140
    Address 17: Instruments Labels: 7L6-920-xxx-7LA.lbl
    Part No: 7L6 920 881 S
    Component: KOMBIINSTRUMENT RB8 3211
    Coding: 0007711
    VCID: 489FE034388BB20161-5140
    Address 18: Aux. Heat Labels: 7L6-819-008.lbl
    Part No: 7L6 815 071 D
    Component: Standheizung E1MAC
    Coding: 0000000
    VCID: 3365A7D8510D21D924-5140
    Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
    Part No: 6N0 909 901
    Component: Gateway K<>CAN 0101
    Coding: 0000006
    VCID: 70EF68D4609B5AC119-5140
    Address 22: AWD Labels: None
    Part No: 0AD 927 755 AT
    Component: TRANSFERCASE 0114
    Shop #: WSC 00000 000 00000
    VCID: 0D1111201769172992-5140
    Address 37: Navigation Labels: 7L6-919-887-CD.lbl
    Part No: 7L6 919 887 K
    Component: Navigation 0734
    Coding: 0000002
    VCID: 4E93D62CDAEF6C312B-5140
    Address 46: Central Conv. Labels: 7L0-959-933.lbl
    Part No: 7L0 959 933 H
    Component: YP HSG 0400
    Coding: 0000081
    Shop #: WSC 33881 000 1048576
    VCID: 4189FD101BB18349A6-4B02
    Subsystem 1 - Part No: 7L0 959 701 K
    Component: Tuersteuergeraet FS 0201
    Subsystem 2 - Part No: 7L0 959 702 K
    Component: Tuersteuergeraet BF 0201
    Subsystem 3 - Part No: 7L6 959 703
    Component: Tuersteuergeraet HL 0202
    Subsystem 4 - Part No: 7L6 959 704
    Component: Tuersteuergeraet HR 0202
    Subsystem 5 - Part No: 7L0 907 719 A
    Component: Neigungssensor 0020
    Subsystem 6 - Part No: 7L6 951 171 B
    Component: Innenraumsensor 0020
    Address 56: Radio Labels: 7L6-035-186-CD.lbl
    Part No: 7L6 035 186 A
    Component: Radio 0734
    Coding: 0005447
    VCID: 3169ADD0AB1113C956-5140
    2 Faults Found:
    00878 - Connection to Speaker Front Left
    012 - Electrical Fault in Circuit
    00879 - Connection to Speaker Front Right
    Address 68: Wiper Electr. Labels: 7L0-955-119-V2.clb
    Part No: 7L0 955 119 L
    Component: Front Wiper 4027
    Coding: 0000341
    Shop #: WSC 31414 000 376832
    Subsystem 2 - Part No: 1K0 955 559 AE Labels: 1K0-955-559-AF.CLB
    Component: RLS 290606 014 1201
    Coding: 00208933
    Shop #: WSC 31414
    Address 69: Trailer Labels: 7L0-907-383-1D2.lbl
    Part No SW: 7L0 907 383 E HW: 7L0 907 383 E
    Component: ANHAENGERELEKTRONIK 8254
    Coding: 0000001
    VCID: 36639ECC427F34F103-5140
    Address 76: Park Assist Labels: Redir Fail!
    Part No: 7L0 919 283 F
    Component: 0E Einparkhilfe 1107
    VCID: 397995F07361DB89EE-5140
    End-------------------------(Elapsed Time: 09:19)--------------------------
    Address 01: DTCs cleared
    Address 09: DTCs cleared
    Address 56: DTCs cleared
  2. Keithuk
    7,079
    That's a new one on me which I've added to may app. As there is nothing on google it
    Which will be the same as the old one.
    VAG Error Code: 17068/001668/4996
    EOBD II Error Code: P0684
    Fault Location:
    Glow Plug Control Module (GPCM) (J179) - Implausible Signal
    Possible Cause:
    Lack/Loss of Power.
    Engine may be harder to start.
    Engine hesitation.
    Wiring/Connector(s).
    Glow Plug Control Module (GPCM) (J179).
    Engine Control Module (ECM).
    Possible Solutions:
