Timing Belt Interval 2011 Jetta
Discussion in 'VW Mk6 Golf, Jetta, Beetle, Sportwagen TDI forum' started by TonyChaudhry, Sep 17, 2012.
  1. TonyChaudhry
    TonyChaudhry New Member
    Aug 15, 2012
    15
    Jetta/2011
    Fort Worth Texas
    I have gotten different number about what mileage I'm suppose to change the timing belt. 80k, 100k, or 120k.
  2. Keithuk
    7,235
    It is strange how you can read different values. The app I'm making shows:
    Jetta 2.0D TDI CR 2008-11
    Engine code: CBDA, CBDB, CEGA
    Replacement Intervals:
    <MY 2009:
    Timing belt - Renew: Every 80,000 miles or 48 months.
    Timing belt tensioner - Renew: Every 160,000 miles or 96 months.
    MY 2010>:
    Timing belt tensioner - Renew: Every 80,000 miles or 48 months.
    Which is the same for all CR engines.
    The newer spec is 120,000 miles or 5 years.
    I'm sure I've read when I was at work that they are 120k. The easiest thing is ask a dealer.
  3. chittychittybangbang
    23,902
    What does it say in your owner's manual maintenance schedule?
  4. mrmmacd77
    mrmmacd77 New Member
    Jun 26, 2012
    47
    2012 VW Jetta Premium
    2012's are 120k or 130k... I'll have a look at break time...
  5. .Shawn.
    .Shawn. New Member
    Sep 19, 2010
    2010 Golf Estate
    My owners manual says 120k for my 2010 JSW. I'm doing it at 100k just for peace of mind. The every 48 month thing sounds ridiculous. The timing belt is very beefy.
  6. mohillic
    mohillic New Member
    Oct 31, 2012
    Jetta TDI/2010
    well gents, against all conventional wisdom, and common sense, i'm at 110k miles on my 2010 TDI and i'm probably going to put, or at least try to put another 10k miles on the car before i get mine changed. wish me luck. I'd do it now but i'm broke.
  7. chittychittybangbang
    23,902
    Check out the mk6 FAQ for the DIY article. I wouldn't worry about another 10k since the owner's manual says 120k. But do change when possible. Even if money is tight, don't skimp on the parts since cheap parts = possible failure and a much bigger repair bill. I rent the special tools which can save you a few bucks.
  8. JCSAG
    JCSAG New Member
    Sep 23, 2013
    2011 JETTA SPORTWAGEN TDI
    Is there a source of info on DYI timing belt replacement?
  9. chittychittybangbang
    23,902
    Yes, the post right above yours says where to find it. Lots more info in the FAQ.
  10. TonyChaudhry
    Aug 15, 2012
    15
    Jetta/2011
    Fort Worth Texas
    I think the manual says 120k and I'm going to be safe and do it at 100k. I think everyone would agree that's probably the best thing. With all the info on this website about how to do it, I'm not going in blind. I'm at 85k right now.
  11. fredhaus
    fredhaus Member
    Sep 2, 2011
    37
    golf tdi 2012
    williams bay,wi
    2012 Golf tdi- I stretched it to 188k miles due to being broke. Tech said everything looked fine, water pump looked like new. The interval they recommend depends on driving style and other factors. At least change it at 150k. Also- time makes the belt more prone to break. A 2000 tdi with only 60k miles could break a belt due to age, belt drying out etc...
    TonyChaudhry likes this.
  12. Crik911
    Crik911 Member
    May 15, 2014
    81
    2011 Jetta TDI Highline (US Version)
    Canada
    None - Factory
    It's that time for me and my 2011 Jetta TDI, 114,000miles on the dash board. I've found a local indie that I trust with a good rep for the job. Next up I need to know what kit people have had good luck with. After we talked for a bit I figured we might as well do a coolant flush and thermostat while she was on the hoist. I haven't done it yet and its recommended every 2 years along with the brake fluid. Might be overkill but I need this thing to last forever. :)
  13. xeno555
    xeno555 Well-Known Member
    Dec 12, 2011
    1,684
    2012 TDI Tech Package 6mt
    Mile High
    The way I see it, is that anything is givin a lifespan.
    This time/mileage (provided by the manufacture) is the safest time to replace before failure under normal use. Will/can it last longer, sure.
    Will it break sooner? Well it could, on rare occurrences or under harsh conditions.
    I personally would not exceed by anything over 10% (playing off manufacturer margin of safety).
    This is not a surprise maintenance, this is a scheduled maintenance that you can start saving for, on mile one, not on mile 119,999.
  14. mohillic
    mohillic New Member
    Oct 31, 2012
    Jetta TDI/2010
    Hi Chitty, I know I'm a few years late replying to this lol, but I did make it to 120. now I'm sitting at 230 contemplating the same thing!!! Here's hoping we make it to January haha.
  15. danstdi
    danstdi New Member
    Aug 15, 2013
    18
    I'm at 197500 all commuting miles on a 2012 mk6 tdi.
    Borrowed time?
    Sent from my VS995 using Tapatalk
    mikeme likes this.
