Timing Belt Change Interval for Cruze TDI and other things.
Discussion in '2014+ Chevy Cruze diesel forum and club' started by TDI2000Zim, Oct 13, 2015.
  1. TDI2000Zim
    TDI2000Zim Member
    Jul 23, 2010
    133
    2000 Beetle TDi...!@#$%...'14 Passat TDiSE
    None
    What is the timing belt change interval for the Cruze TDI?
    How about maintenance intervals for auto transmission?
    Fuel filter change interval?
    Any other facts that make it more user friendly than VW TDIs?
    23,721
    At this time I know it uses an older HPFP design. It may be more reliable.
    Timing belt is 97,000 miles. Water pump too.
  3. tom w
    tom w New Member
    Feb 12, 2016
    vw,jetta,2009
    cloquet,mn 55720
    Can, t get fuel to the injectors?
    We have fuel to the pumps
  4. Vwman2015
    Vwman2015 Member
    Oct 3, 2015
    291
    Vw golf, mk5 2005 sdi, bkd engine
    Clacton
    Have you replaced the timing belt by any chance?
  5. tom w
    tom w New Member
    Feb 12, 2016
    vw,jetta,2009
    cloquet,mn 55720
    it was a VW Jetta 2009 TDI,We changed the belts, water pump, pulleys and bolts. Checked to make sure the timing was right three times . primed the pump two different times (3 times for 60 seconds) and also the aux pump 3 times for 60 seconds. We have fuel up to the rail but no fuel to the injectors . Is there something that tripped and is not letting the fuel go in the rail? Does anybody know? Help
  6. Vwman2015
    Vwman2015 Member
    Oct 3, 2015
    291
    Clacton
    Have you checked the injector wires incase the wires have lost connection,
    You checked fuses?
    You could also check the continuity on each injector plug.
  7. Vwman2015
    Vwman2015 Member
    Oct 3, 2015
    291
    Clacton
    It's a common rail design so you could also check the injectors by removing one and placing it in a clear bottle to see if they spray.
    The fuel pump on these only have to be a nats ass out and the timing is out on the fuel.
    Have you plugged it into a vcds to see timing etc etc??
    I hope this helps
