The teeth on my timing belt shredded in my 2005 TDI Jetta, BEW
Discussion in 'Mk5 VW Jetta, Sportwagen, and Audi A3 TDI forum' started by roj7782, Dec 13, 2016.
  1. roj7782
    roj7782 New Member
    Dec 13, 2016
    VW jetta 2005 TDI, BEW
    NJ
    The teeth on my timing belt shredded in my 2005 TDI Jetta, BEW. The Cam is 9 o'clock. How do I adjust this to TDC without screwing it up?
  2. crsmp5
    crsmp5 Well-Known Member
    Feb 14, 2012
    1,550
    85 kubvan
    ll its like doing the cam job after you replace the valves you bent, yes time to pull the head
  3. Keithuk
    7,235
    Title changed from help everyone needs help and moved to correct section.
  4. thzpcs
    thzpcs Member
    Jun 30, 2016
    70
    2008 Golf TDI
    Golden, CO
    Is there any chance it could have jumped without killing the valves? I had a GTI that jumped timing, and somehow managed to remain unscathed.
  5. crsmp5
    Feb 14, 2012
    1,550
    85 kubvan
    head/piston/rod costs more then set of valves... cause the head pops off if ya dont.. they crack, not bend..
    head of valve then destroys head/piston and tend to bend rod too..
  6. gt4494
    gt4494 Active Member
    Jan 15, 2011
    440
    2005 NB
    Southeast Coast on I-95. Radar detector on and yes Herbie still gets 40mpg at 80 mph
    Unfortunately the Diesel is an "interference fit". This means that the valves occupy the same space as the piston when they are open. They piston will hit them if they are open when the piston comes to TDC. If the engine had any RPM higher than idle when the belt stripped you really need to pull the head and have it inspected for bent /cracked valves. Normally the pistons will be OK but they deserve a look at their tops to make sure they didn't crack.
