Terrible Radio Signal
Discussion in 'VW Mk6 Golf, Jetta, Beetle, Sportwagen TDI forum' started by Cybermenace, Mar 18, 2017.
  1. Cybermenace
    Cybermenace New Member
    Mar 18, 2017
    5
    Golf GT TDi 140
    United Kingdom
    Hi folks I have a 2009 Golf Mk6 I have very poor FM radio signal in my car, has anyone else who has had this or do they if anyone has a solution for this?
    When stationary the signal is fine but when driving around it's more or less useless I just can't get a decent signal,
    Radio is a RNS-315 DAB antenna is in the rear window not an external antenna,
    It has worked perfectly until now but I just seem to get a signal for a small amount of time when i driving along RDS is on but doesn’t make a difference ,
    The problem is across all FM channels. It doesn't seem to be related to surrounding buildings, I really need this fixed as I am at a loose end with this and need to find a solution.
    I have noticed that in the hidden menu under FM ANT1 & ANT2 is off & AM ANT is off also,
    But under DAB ANT is showing as on.
    So far I have replaced the amplifier which isn't the issue, or they sent me a faulty part,
    How would I know the amplifier is getting power?
    Thanks
    Billy
    [​IMG]
    Replacement amplifier :
    [​IMG]
  2. limso
    limso New Member
    Apr 10, 2017
    Seat Leon 1.6 TDI
    Croatia
    Hi i dont think you have a problem with the radio its probably a bad wire connection or a bad wire...try to get the radio out and check the jacks also check the antenna wire...maybe if you can try different antenna?
    Cybermenace likes this.
  3. Cybermenace
    Mar 18, 2017
    5
    Golf GT TDi 140
    United Kingdom
    The radio is fine I have tried it in another car and everything is fine it's going to have to be one of these modules that's the problem.
    limso likes this.
