Temperature gauge
Discussion in 'VW Mk3 Jetta, Passat TDI and other/older diesels' started by BOBMATTHEWS, Mar 18, 2017.
  1. BOBMATTHEWS
    BOBMATTHEWS New Member
    May 17, 2013
    21
    2005 Passat TDI
    Seattle
    My question is simple if the car is running fine but the temp reading on dash is below normal (12 o'clock position)operating position, is that a concern?
    Obviously not overheating, is there such a thing as underheating?
    Would it be the thermostat or the temp sending unit that might be needing replacement. Coolant was low a bit but topped it off and it is staying topped off but no change in not getting to needle on temp dash pointing straight up, a bout to the left.
  2. BOBMATTHEWS
    May 17, 2013
    21
    2005 Passat TDI
    Seattle
  3. crsmp5
    crsmp5 Well-Known Member
    Feb 14, 2012
    1,280
    85 kubvan
    does engine temp read same as gauge?? the duel sensors fail... throwing one of the 2 off
  4. j_martell
    j_martell New Member
    Dec 4, 2014
    6
    2006 Jetta GLS TDI Wagon (MK4 BEW A09)
    Centre Wellington, Ontario
    The dash gauge is buffered.....
    I run a scangauge II and monitor engine and auto trans temps. The gauge on the dash will show 90*c (190*F, or the 12 o'clock position) when the coolant is 75-95*c.
    Colder motors will burn more fuel per the maps in the ECU, hurting cold weather milage and causing excess soot in the motor/turbo/exhaust...
  5. BOBMATTHEWS
    May 17, 2013
    21
    2005 Passat TDI
    Seattle
    Is it the thermostat that needs replacing. Temperatures here are 45-60 now any way so not too cold.
  6. crsmp5
    Feb 14, 2012
    1,280
    85 kubvan
    YES IF BOTH ENGINE AND GAUGE READ LOW... no if only one is
