1. eddi887
    eddi887 Member
    Jun 18, 2017
    50
    2003 Jetta TDI
    Dale Texas
    Air intake
    Hi All,
    The rear speakers in my 2003 Jetta aren't working. I've checked the wiring in the doors and it looks fine; pulled and reset the connector too.
    I read somewhere that the amp could be causing this issue. Does anyone have any information that would help me troubleshoot this problem?
    Also, it did not have original stereo when I bought it, just some cheap Pioneer. I have replaced that with a Kenwood.
    Thanks...Jeff
  2. MrRussNoFuss
    MrRussNoFuss New Member
    Jan 3, 2018
    4
    2006 VW New Beetle 1.9
    LooseBananas
    it breaks i pay to fix
    im not sure what amp you have but could you possibly switch the front/rear outs from your amp? I have had channels on amps go out and i swapped the output to a channel i knew worked. that could tell you if the speaker was bad or the channel.
  3. Keithuk
    7,235
    Do you have access to VAG-COM\VCDS to check the system with output test?
    I have 40 error codes for speaker which is basically check all wiring & connectors. Do a resistance check.
    Check resistance of no output speaker and compare it with a speaker that works.
    Speaker resistance can vary between 1, 2, 4 & 8 Ohms.
    Perform Output Test.
    Fitting aftermarket stereo's causes more problems.
