some info for those that use DEF
Discussion in 'General Diesel Discussion' started by laminated, Apr 22, 2017.
  1. laminated
    laminated New Member
    Apr 13, 2017
    13 passat 15 golf
    eastern Canada
    I was on a seminar and DEF use came up, Some points to know include,
    Store it in a cool dark place
    It has a shelf life, so dont think you can store it for years
    If you pour it in a funnel,, DO NOT use a black plastic or a metal one as def leeches oils etc out of them and attacks the metal also,
    A tiny bit of oil will contaminate a large quantity of DEF, so clean a funnel spotlessly if its seen oil.
    23,901
    Nice tips on the funnel material. Never heard of that one.
  3. diesel2
    diesel2 Member
    Jul 28, 2015
    32
    2010 Jetta TDI 6 Speed Standard
    Barrie Ontario Canada
    I was also told keep it topped up as other wise will cause one problems. Do not let it go till it gets to the point it is near the empty mark, reason being if one does this all the time the water in evaporates off making the strength too strong and will cause one problems. So keep any car or truck using it always topped up. Do not let the tank run down too low from full. That info was from some one who has seen the problem on many car and trucks. So for what it is worth there it is.
