Skodia Octavia ALH engine mount problem
Discussion in 'SEAT and Škoda TDI' started by JHNW, Nov 24, 2011.
  1. JHNW
    JHNW Member
    Nov 7, 2011
    39
    2001 Skodia Octavia 1.9TDI
    Whilst changing the timing belt I managed to remove the engine mount that bolts to the block...didn't realise it could stay there and be worked around....now I can't get it back in!! Is there a trick to it? I'm worried about raising the engine up too much with the jack. Spent an hour on this already.
  2. YMZ
    YMZ Super Moderator
    Sep 22, 2010
    2,112
    Jetta 2003, Golf 2001
    Yes, there are a couple of magic spots where that lower engine mount ("bracket") can escape... Generally if the engine's on the low side, it's easier...
    It's also much easier if you remove the intake air snorkel to the turbo... (2 bolts and the hose clamp...)
    Good luck,
    Yuri
  3. kd7iwp
    kd7iwp New Member
    Jul 10, 2009
    15
    I had the same problem. I had taken the bracket out (my mistake) and couldn't find a way to install it with the new timing belt in. So I removed one of the small rollers and was then able to get the bracket in (with the engine lowered) and then could reinstall the roller and tension the belt.
