Skoda Octavia 2.0 TDI oil leak
Discussion in 'SEAT and Škoda TDI' started by bradh, Sep 5, 2017.
  1. bradh
    bradh New Member
    Sep 4, 2017
    11
    Skoda Octavia vrs mk2
    Redditch uk
    Hi guys iv noticed a oil leak on the back of the engine it's on the (as you look from front of car right hand side), of the block round the back it's running down wards so what's in the area that would cause an oil Leake, defiantly engine oil too
    Any info very much welcome
  2. bradh
    bradh New Member
    Sep 4, 2017
    11
    Redditch uk
    hi all only had my car under 2 weeks and iv noticed that there is a oil leak from the back right hand side of the engine after every drive its fresh oil, leaks all down the block onto top of the Gearbox, is this a common leak ?? My cars under warrentee so hopefully going into be fixed very soon.
    Just woundering if this is common no I should be worried bout this :(
  3. Seatman
    Seatman Well-Known Member
    Jul 9, 2010
    5,827
    Scotland
    PP764's, turbo and mapping
  4. Dave N
    Dave N Member
    May 31, 2015
    72
    06 Golf TDI BEW 09A
    Spokane Wa
    Could be the valve cover gasket if there is oil up high or the oil return hose that comes from the turbo
  5. bradh
    bradh New Member
    Sep 4, 2017
    11
    Redditch uk
    Hi nar it's slightly lower the these 2 items :(
  6. bradh
    bradh New Member
    Sep 4, 2017
    11
    Redditch uk
    Is it possible to remove the rocker arm shaft in the head without touching the timing so I can re torque the head back down ??
  7. Dave N
    Dave N Member
    May 31, 2015
    72
    06 Golf TDI BEW 09A
    Spokane Wa
    Yes but both the head bolts and rocker bolts are torque to yield bolts and designed as one time use. When you say right side do you mean the right side as you are looking at the engine/transmission from the front? Can you post a photo of the area you are talking about?
  8. bradh
    bradh New Member
    Sep 4, 2017
    11
    Redditch uk
    Yea right hand side looking from the front, it's below the oil feed pipe for the turbo Ware it goes round the back of the block
  9. bradh
    bradh New Member
    Sep 4, 2017
    11
    Redditch uk
    Have another leak we’ll I've found one behind the inlet manifold at the front changed the orange gasket the week end lasted leak free for 24 hours now it’s leaking again, any surgestions for this as it’s making a mess he he
    Cheers brad
  10. bradh
    bradh New Member
    Sep 4, 2017
    11
    Redditch uk
    Thought I’d kill this off fitted the BKD metal inlet with metal gasket sorted my leak on the front,
    And other oil leak was intact the head gasket failing :(
