Skoda Fabia 1.9tdi pd 100 year 2005 5 dtc's
Discussion in 'SEAT and Škoda TDI' started by landroverbob, Aug 12, 2017.
  1. landroverbob
    landroverbob New Member
    Dec 30, 2010
    13
    sharan 1998 passat3, golf2, land rovers, argocat
    Done all I can think of that's obvious, can any one see the connection in these fault codes?
    5 Faults Found:
    17957 - Boost Pressure Regulation Valve (N75): Open or Short to Ground
    P1549 - 35-10 - - - Intermittent
    17849 - EGR Valve (N18): Open Circuit or Short to Ground
    P1441 - 35-10 - - - Intermittent
    19561 - Valve for Intake Manifold Flap (N239): Open or Short to Ground
    P3105 - 35-10 - - - Intermittent
    18027 - Glow Plug Relay (J52): Open or Short to Ground
    P1619 - 35-10 - - - Intermittent
    17660 - Cold Start Injector (N108) Open or Short to Ground
    P1252 - 35-10 - - - Intermittent
    must be a common denominator?
    lrb
  2. Keithuk
    7,235
    Its nice to see you have posted in the new Seat and Skoda TDI sub forum. ;)
    VAG Error Code: 17957/005449
    EOBD II Error Code: P1549
    Fault Location:
    Solenoid Valve for Boost Pressure Control (N75) - Open Circuit/Short Circuit to Earth
    Possible Cause:
    Irregular behaviour.
    Loss of power.
    Limp mode.
    Limp mode: What is it, what are the causes, and how to fix it for the Audi and VW TDI diesel turbo.
    Wiring/Connector(s).
    Solenoid Valve for Boost Pressure Control (N75) faulty.
    Possible Solutions:
    Check/Replace Solenoid Valve for Boost Pressure Control (N75).
    VAG Error Code: 17849
    EOBD II Error Code: P1441
    Fault Location:
    Exhaust Gas Recirculation (EGR) Valve/Solenoid, Bank 1 - Open Circuit/Short Circuit to Earth
    Possible Cause:
    Fuse(s).
    Wiring/Connector(s) open circuit/short to earth.
    Exhaust Gas Recirculation (EGR) Valve/Solenoid.
    Possible Solutions:
    Check/Replace Fuse(s).
    VAG Error Code: 19561/012549
    EOBD II Error Code: P3105
    Fault Location:
    Valve for Intake Manifold Flap (N239) - Open Circuit/Short Circuit to Earth
    Possible Cause:
    Engines shakes at shutdown.
    Fuse(s).
    Wiring/Connector(s) open circuit or short to earth.
    Valve for Intake Manifold Flap (N239) faulty.
    Possible Solutions:
    Check Wiring for open circuit or short to earth.
    Check Valve for Intake Manifold Flap (N239) > Output Test.
    VAG Error Code: 18027/005657
    EOBD II Error Code: P1619
    Fault Location:
    Glow Plug Relay (J52) - Open Circuit/Short Circuit to Earth
    Possible Cause:
    Fuse(s).
    Glow Plug Relay (J52) faulty.
    Possible Solutions:
    Check Glow Plug Relay (J52).
    Perform Output Test.
    VAG Error Code: 17660
    EOBD II Error Code: P1252
    Fault Location:
    Cold Start Injector (N108) - Open Circuit/Short Circuit to Earth
    Possible Cause:
    Fuse(s).
    Cold Start Injector (N108).
    Possible Solutions:
  3. Seatman
    Seatman Well-Known Member
    Jul 9, 2010
    5,827
    Scotland
    PP764's, turbo and mapping
    If you clear the faults but that lot keeps coming back I'd be checking earth points, battery cables, earth strap to gearbox etc.
    If it was only a couple it'd be different but that's quite a lot
