Seat ibiza 1.6 tdi cr 2014 model and torgue app
Discussion in 'SEAT and Škoda TDI' started by wwiimaniac, Nov 13, 2017.
  1. wwiimaniac
    wwiimaniac New Member
    Sep 13, 2017
    Seat ibiza 1.6 tdi 2014
    Greece
    i want to see the ACTUAL boost for my car. I use an obd and torgue app and i have min value -0.3 psi wich is ok and 22-23 max value.... the boost goes up normally when I press the pedal to the botom.... do I see the actual boost or the boost that the ecu demants? For example with vag-com cable and vcds you see both the demanded boost from the ecu and the actual boost....
