Seat Arosa limp mode problem
Discussion in 'SEAT and Škoda TDI' started by mininick, Aug 23, 2015.
  1. mininick
    mininick New Member
    Jun 25, 2015
    seat arosa pd 1.4 turbo 2000
    redditch, uk
    none
    Hi. I'm new to this forum, so please excuse if this post needs redirecting. Have recently been having boost problems with arosa 1.4 turbo following broken cambelt/headgasket replacement. This is the sawn down 3 cylinder pd engine, non variable vane, wastegate, pressure actuated turbo. Having changed two valves and damaged followers, headgasket and bolts etc (genuine) cambelt (timing checked several times) replaced all smallbore vacuum/pressure pipes, checked all boost/intercooler pipes for leaks/damage, new MAF, MAP, coolant temp sensor, N75 valve, all bosch/pierburg, removed exhaust and inspected turbo, wastegate sealing disc, pressure testing wastegate actuator (all looking and performing like new) the car still intermittently slips into limp mode, usually under load, when not limping goes like a train, throws up negative boost pressure fault code, cycling ignition clears problem. We have applied our combined knowledge of 93 years to this and are completley stumped. Any new input would be greatly appreciated.
  2. Keithuk
    7,239
  3. mininick
    mininick New Member
    Jun 25, 2015
    redditch, uk
    none
    Hi. Thanks for your reply. The one code that keeps coming up is P1556 charge pressure control negative deviation.
  4. Keithuk
    7,239
    Sorry for the late reply.
    VAG Error Code: 17964/005462
    EOBD II Error Code: P1556
    Fault Location:
    Charge Pressure Control - Negative Deviation
    Possible Cause:
    Reduced power output.
    Limp mode.
    Boost Pressure too Low.
    Hoses/Pipes incorrectly connected, disconnected or leaking.
    Charger Pressure Control defective.
    Variable Nozzle Turbo (VNT) nozzles stuck.
    Charge Pressure Control Solenoid Valve (N75) defective.
    Possible Solutions:
    Check Hoses/Pipes to/between Components.
    Check Charge Pressure Control Solenoid Valve (N75).
    Check/Clean/Replace Charge Pressure Control.
    Check/Clean mechanism for variable nozzles.
