Replacing injectors on a BEW
Discussion in 'VW Mk4 Jetta, Golf, New Beetle, Passat TDI forum' started by luxuryrules, Apr 18, 2017.
  1. luxuryrules
    luxuryrules Member
    Oct 24, 2014
    77
    2004 Jetta TDI
    USA
    Looking at upgrading injectors on my 04 BEW Jetta. I replaced the cam last year and that was... a job. I see the injectors are under the valve cover, but I don't remember quite how they were fastened in.
    Can I do this by simply removing the valve cover? Need I be at TDC? Anything beyond pulling the injector rockers off and lifting the injectors out?
  2. crsmp5
    crsmp5 Well-Known Member
    Feb 14, 2012
    1,550
    85 kubvan
    new bolts for the rockers to as tty...
    the injector has a bolt at the base of it... gotta drain cooling system... i beleive there is coolent flow around the injectors and will make you a nice mess.. now the trick is the tool to get the injector out of the head... i watched a guy jumping up and down on a 10 ft cheater bar bend a injector body... he refused to wait for me to grab my "lady finger" a 12" prybar that the end is 90* to the shaft and flat like a screwdriver.. i slipped it into the gap by the bolt anchor spot.. gave it a twist like loosening a screw with the tip.. pop out 3 were in 45 sec.. the bent one took me a hour as bent in such a way it had interfearance fitment issues now.. my pool would have never allowed it to get bent
  3. crsmp5
    Feb 14, 2012
    1,550
    85 kubvan
  4. luxuryrules
    luxuryrules Member
    Oct 24, 2014
    77
    2004 Jetta TDI
    USA
    Ok, so the gist of it is, drain coolant, remove valve cover, undo bolt at base of injector, pry out with fine tool (thank you for links!!!); then installation is reverse of removal?
  5. crsmp5
    Feb 14, 2012
    1,550
    85 kubvan
    pretty much... new o rings and such for the injectors.. lotsa lube on new ones when installing.. to damage a o-ring will fill coolent, or oil.. or both with diesel.. i do the twist while pressing into place as to not nick the o-rings.. not alot of room to twist..
  6. luxuryrules
    luxuryrules Member
    Oct 24, 2014
    77
    2004 Jetta TDI
    USA
    Forgot to check - do I need to drain oil too?
