Replacement of a crankshaft sensor 06 vw jetta tdi 1.9
Discussion in 'Mk5 VW Jetta, Sportwagen, and Audi A3 TDI forum' started by Ambergonzalez1987, Dec 22, 2016.
  1. Ambergonzalez1987
    Ambergonzalez1987 New Member
    Dec 22, 2016
    5
    2006 vw jetta tdi 1.9 diesel
    Washington
    I have been having issues with my jetta I'll be at a light or on a hill and it dies for no reason. I have looked into it a little and seeing everyone saying it's the crankshaft sensor I tried looking for it and can't seem to find where it located, can anyone help please?
  2. Keithuk
    6,771
  3. Ambergonzalez1987
    Dec 22, 2016
    5
    Washington
    But its a 2004 I have a 2006
  4. Keithuk
    6,771
    I couldn't find a 2004 video but its the same if you google it
  5. xeno555
    xeno555 Well-Known Member
    Dec 12, 2011
    1,603
    2012 TDI Tech Package 6mt
    Mile High
    Also 2004 is not MK6
  6. Keithuk
    6,771
    Well spotted thread moved. [​IMG]
  7. John Mack
    John Mack New Member
    Nov 3, 2015
    19
    2005.5 JETTA TDI /2015 JETTA TDI
    OREGON
    The crankshaft sensor for the BRM engine is an integral part of the rear main crankshaft seal. To replace it, the transmission needs to be removed. A special tool is required to install the new seal/ sensor and to correctly reinstall the "sender" ring on the crankshaft in the correct position. The engine will also have to be locked at TDC using the appropriate crank locking tool. Failure to use the proper tools will result in an engine that will not run or run poorly. There is a YouTube video for installing the rear oil seal on the BRM engine. I would highly recommend viewing the video to see if it is something that you want to get into. A new seal tool goes for $200 + or you may be able to rent from someone on this forum. The seal/ sensor sells for aprox $60-80. A shop will probably charge $600 + to replace the rear seal.
    Sent from my SAMSUNG-SM-G900A using Tapatalk
  8. thzpcs
    thzpcs Member
    Jun 30, 2016
    40
    2008 Golf TDI
    Golden, CO
  9. John Mack
    Nov 3, 2015
    19
    OREGON
    Part of the sensor is included on the seal carrier. This (036-906-433-E) is the part that attaches to the part on the rear main crankshaft seal. Take a look at this post for more info on the crankshaft sensor and malfunction causes and repair.
    http://forums.tdiclub.com/showthread.php?p=4234028
  10. John Mack
    Nov 3, 2015
    19
    OREGON
    Be sure to scan for DTC codes first to ensure that the sensor is your problem. The only sure way to diagnose your problem is by using a scanner to get a read out of the DTC's. If you don't scan, you will be taking "a shot in the dark" and may spend a lot of money & not solve the problem.
    Here is detailed information on the sensor / seal replacement if it is the problem.
    http://www.myturbodiesel.com/wiki/r...peed-sensor-replacement-on-a-mk5-vw-and-audi/
  11. Ambergonzalez1987
    Dec 22, 2016
    5
    Washington
    My car is a 2006 volkswagon jetta tdi 1.9 diesel not a mk5
  12. Ambergonzalez1987
    Dec 22, 2016
    5
    Washington
    My car is not a 5 speed its a automatic 2006 vw jetta tdi diesel 1.9 turbo
  13. John Mack
    Nov 3, 2015
    19
    OREGON
    The 2005.5 thru 2010 are "MK5" body style and look the same on the outside but vary in engine type and accessories
  14. John Mack
    Nov 3, 2015
    19
    OREGON
    The sensor is the same for manual or automatic.
    Do a scan first to verify cause of problem
  15. John Mack
    Nov 3, 2015
    19
    OREGON
    A 2006 is a MK5 series vw
