Replaced injectors: smoke and bad mileage
Discussion in 'VW Mk3 Jetta, Passat TDI and other/older diesels' started by Rig, Apr 11, 2017.
  1. Rig
    Rig Member
    Jul 19, 2011
    60
    2006 Jetta TDI, 1998 Jetta TDI
    Southeast Alaska
    We just replaced the stock injectors on our 98 TDI with Bozio 520. It smokes, and the mileage has gone from over 50 mpg to around 40 mpg or less. I guess these nozzles are nominally .205 but act like larger ones. I might hold onto these for when I get a turbo and chip upgrade, but in the meantime, I would like to go back to higher mileage and no smoke. Suggestions?
  2. YMZ
    YMZ Super Moderator
    Sep 22, 2010
    2,126
    Jetta 2003, Golf 2001
    Do you have access to VCDS or equivalent? You should adjust the I.Q. for new nozzles...
    BTW: I'm assuming you didn't have the injector/nozzle combination tested... (pop pressures, flow...)
    520 nozzles shouldn't cause a drastic drop in fuel economy - as long as you can resist the urge to floor the accelerator consistently...
    Yuri
