relay 109
Discussion in 'New TDI forum member introductions' started by mkIV, Mar 12, 2017.
  1. mkIV
    mkIV New Member
    Mar 12, 2017
    2003 vw golf 1.9 tdi mk4
    Ontario, Canada
    relay 109 was unplugged while car running ...help no cranking! what happened
  2. Keithuk
    7,239
    Relay 109 doesn't effect cranking its the main power feed to the ecu. You need to check the system out.
  3. mkIV
    mkIV New Member
    Mar 12, 2017
    Ontario, Canada
    Thank you very much. we are trying to figure out how to reset the ecu.
  4. Seatman
    Seatman Well-Known Member
    Jul 9, 2010
    5,827
    Scotland
    PP764's, turbo and mapping
    No cranking as in not turning over? That's nothing to do with the ecu, means power isn't getting to the solenoid on the starter.
    Could be a fuse maybe
  5. Keithuk
    7,239
    Do you have a fuse & relay diagram? I have 2003 Golf-Bora 1.9 SDI Fuse & Relays if you want it?
    Fuse & Relay PDF Files
    No.9 relay in relay carrier under the dash (175) - Relay for Starter Inhibitor and Reversing Light (J226)
