R5 Misfire help needed
Discussion in 'Ross Tech VCDS forum' started by 4ePikanini, Nov 5, 2012.
  1. 4ePikanini
    4ePikanini Member
    Sep 16, 2012
    53
    2005 Touareg R5
    Driving a long journey yesterday and halfway to home the car started vibrating.
    It vibrates a lot when idling and under load below 3000rpm.
    I nursed the car home with very light throttle. (A bottle of injector cleaner went in before the journey - when empty I refilled the tank with diesel without any additives and the problem persists)
    I scanned it and VCDS returned a misfire on cylinder 5. It comes back after a few seconds if I clear it.
    I tried disconnecting the ecu for a few minutes but that made no difference.
    I tried disconnecting the egr, throttle butterfly and MAF. That made no difference
    I changed the fuel filter. That made no difference.
    I pulled the tappet cover and the lobes aren't worn at all. I also disconnected the injector connectors, cleaned the contacts and reinserted. That made no difference.
    I then thought it may be an electrical issue.
    I ran some measuring blocks and this is the result.
    NB: The injector mg/str is multiplied by 10 on the chart to exagerate. The attached log file is as it was logged via VCDS.
    1638rpm in "Park".
    [​IMG]
    Idle measurements
    [​IMG]
    Chart of measurements -> Start -> revving in "Park"
    [​IMG]
    Log file
    [​IMG]
  2. 4ePikanini
    4ePikanini Member
    Sep 16, 2012
    53
    2005 Touareg R5
    I have also disconnected and cleaned the injector harnass connection at the back of the head. It didn't help.
  3. majeka
    majeka New Member
    Jan 23, 2012
    a4 tdi 2006
    I have similar problem with R5 how did you get on with the misfire
