Prophylactic tandem pump?
Discussion in 'VW Mk4 Jetta, Golf, New Beetle, Passat TDI forum' started by jeffhodge69, May 16, 2017.
  1. jeffhodge69
    jeffhodge69 Member
    Mar 25, 2011
    47
    2006 Golf TDI
    Northern KY
    Green Diesel Engineering Tune, Diesel Geek Short Throw Shifter
    Hey Gents!
    Finishing up cam swap/TB job. Car has 200K on it....would you guys replace the tandem pump just because? Now would be easy except for the wallet pain, but I figure it's gonna go at some point....right?
  2. drucifer
    drucifer Member
    Nov 3, 2013
    146
    2004 jetta tdi pd wagon
    fredericksburg va
    panzer plate fmj
    If it's not leaking leave it alone. Leave your money in wallet for something that's actually broken.
  3. crsmp5
    crsmp5 Well-Known Member
    Feb 14, 2012
    1,550
    85 kubvan
    ive yet to remove one of those pumps when doing a cam... so do not see any reason why now vs later matters :rolleyes:
  4. smhorvat
    smhorvat New Member
    Feb 28, 2013
    Oklahoma
    Are you saying to leave the pump alone and not remove it when doing a cam swap?
  5. crsmp5
    Feb 14, 2012
    1,550
    85 kubvan
    yea.. no fuel leaks.. once belt off i turn the crank ccw 90* so all 4 pistons mid stroke... then i turn the cam so the slot is up to remove it... when installing a cam i like to rotate it as i torque the bolts... so i always ccw the crank.. just a added bonus no pull/touch the pump...
    why turn the cam as toquing it... if YOU screw up and put some cap on backwards or in wrong place.. it will 99% of the time lock the cam from turning before breaking... if it locks solid then you know last bolt touched has a issue.. the injector rockers will add alot of effort.. the cam... not even a 1/4 the resistance
