Procedures for assembling rebuilt AHU
Discussion in 'VW Mk3 Jetta, Passat TDI and other/older diesels' started by A1TDI, Nov 8, 2017.
  1. A1TDI
    A1TDI New Member
    Nov 8, 2017
    1983 Rabbit AHU Swap
    Lancaster
    I am treading carefully here and trying to do research before I start installing the timing components and other assessories on my rebuilt AHU. I have a few questions for he board about the installation sequence.
    Set the scene: I have the block assembled, head is on torqued down, pistons are at equal heights. Cam is in TDC position.
    Questions:
    1. Should I put motor back to TDC in preparation for installing the timing components? Will this be too risky without there flywheel marker? Should I buy a crank lock tool?
    2. How should I install the cam sprocket(method of counter-holding?)
    3.i have no idea what timing the injection pump is at right now, any suggestions for installation? How should I counter hold the IP pulley for installation?
    Basically what I am asking is what is the best practice for getting a TDI ready from a bare block? I’m confident just a little unsure where to take the first step.
    Thanks everyone!
    -Paul
