plastic broke off in manual transmission oil
Discussion in 'VW Mk4 Jetta, Golf, New Beetle, Passat TDI forum' started by Brettimus_Prime, May 9, 2017.
  1. Brettimus_Prime
    Brettimus_Prime New Member
    Jan 14, 2017
    9
    2004 Jetta Wagon PD BEW Manual
    Chicago
    I upgraded the cup holder with a Goose Island
    2004 BEW with 5 speed
    I was doing my gear oil change and one of the plastic wings from my hand pump broke off into the transmission. Tried draining the oil but didn't come out.
    [​IMG]
    Can I remove the plate with VW on it to fish it out?
    [​IMG]
  2. crsmp5
    crsmp5 Well-Known Member
    Feb 14, 2012
    1,550
    85 kubvan
    no... thats the bottom of the shift tower.. no room there
  3. jeffhodge69
    jeffhodge69 Member
    Mar 25, 2011
    47
    2006 Golf TDI
    Northern KY
    Green Diesel Engineering Tune, Diesel Geek Short Throw Shifter
  4. jeffhodge69
    jeffhodge69 Member
    Mar 25, 2011
    47
    2006 Golf TDI
    Northern KY
  5. audi1z
    audi1z Member
    Oct 16, 2010
    415
    Audi 80 1Z Engine
    Have you ever seeen a gearbox from inside? No chance with a camera.
    If it is really plastic and tiny, leave it where it is. The alternative is to dismount the differential housing.
    What ever the reason for oil change was, why did you not use the oil drain screw at the bottom of the gearbox?
  6. chittychittybangbang
    23,900
    Ah, the joys of working on a car!
    Without a lot more access, as audi1z said, it's gonna be hard to get it out unless you can shake it loose somehow. Magnets won't work so I don't know how otherwise then fishing around for it.
  7. jeffhodge69
    jeffhodge69 Member
    Mar 25, 2011
    47
    2006 Golf TDI
    Northern KY
    Sorry, not real familiar with VW gearboxs, the Ford toploader and Muncie M21 I rebuilt you probably could play around with a camera. Hang in there brother, always hate this kind of stuff. Nothing's ever easy! LOL
  8. crsmp5
    Feb 14, 2012
    1,550
    85 kubvan
    well i should NOT SAY THIS... so huge disclaimer!!!!!!!!
    if its ONLY plastic, no metal in it... i know of people who lost the speedo gear into the old 020 tranny... the plastic just gets eaten away by the metal stuff inside the 020.. so if its just that little tang hanging off the side... id not worry as much as i would with a speedo gear...
    next if you remove the speedo gear on your 02j style tranny.. i prefer to fill there a exact 2 quarts via a nice long "super funnel" no mess and easy...
  9. Brettimus_Prime
    Jan 14, 2017
    9
    Chicago
    Thanks everyone. After some research I've decided to drive it for a hundred or so miles and drain the oil again to see if I see plastic bits. Going to go ahead and rip the other tang off before I fill up again. I just gotta get this stupid Eurovan out of the garage so I can do the control arms on the Jetta Wagen before I drive her around.
    Will post an update
