Passat Syncro AFN 110 hp - Timing problem
Discussion in 'VW Mk3 Jetta, Passat TDI and other/older diesels' started by Teo Todorov, Nov 5, 2016.
  1. Teo Todorov
    Teo Todorov New Member
    Jun 10, 2015
    VW, Passat B5 Syncro, 1998
    Bulgaria
    1.9 AFN
    Hi everyone! The problem is, that the timing are too much in advance - more than 255. I try to retard it, but in the position, where must be 60-65, the pump won't to work. To have a normal start, the pump must be in too advance. I have error code 00550 - Start of injection regulation. I check everything - mark on flywheel, camshaft and IP, and it's ok! The crankshaft pulley and bolt are new... There something on timing belt pulley: the mark has moved for a while, then back again on the right position. I adjust it a several times, but is the same situation. With this timing, the car smoke very much, and the start are very hard. Please help!
  2. Seatman
    Seatman Well-Known Member
    Jul 9, 2010
    5,827
    Scotland
    PP764's, turbo and mapping
    Try going advanced, after 255 it goes back to zero so you shouldn't need to advance it far to get in spec.
