Passat AVF leaking front crank seal?
Discussion in 'VW Mk4 Jetta, Golf, New Beetle, Passat TDI forum' started by Inspector 71, Mar 11, 2017.
  1. Inspector 71
    Inspector 71 New Member
    Mar 11, 2017
    VW Passat 1.9 TDi B5.5 2002
    Scotland
    Hi All
    I've got the front end off my car to do a timing belt and water pump. There is quite a bit of oily gunk on the bottom timing cover and behind the crank sprocket. There's also a fair bit of oil around the bottom of the intercooler.
    Is there a quick way to do the front seal or do I have to remove the carrier and sump pan etc?
    Thanks in advance
    George
  2. crsmp5
    crsmp5 Well-Known Member
    Feb 14, 2012
    1,277
    85 kubvan
    better hope the bsm chain did not wear a hole thru it
