Oxygen Sensor Fault and Engine Light
Discussion in 'VW Mk6 Golf, Jetta, Beetle, Sportwagen TDI forum' started by TDISportAaron, Feb 27, 2017.
  1. TDISportAaron
    TDISportAaron New Member
    Jan 10, 2017
    13
    2008 VW Tiguan 2.0 TDI 170 SE
    UK
    Hello people,
    This-morning driving to work (VW Scirocco GT TDI 170) I had the engine management light come on, when I arrived I plugged in my VCDS cable and software and it reported the following fault:
    Address 01: Engine (CBB) Labels: 03L-906-022-CBA.clb
    Part No SW: 03L 906 022 LC HW: 03L 906 022 G
    Component: R4 2,0L EDC G000SG 6655
    Revision: 13H03--- Serial number:
    Coding: 0001072
    Shop #: WSC 14384 028 460582
    VCID: 71BCDF250DAA3EAFD27-8024
    1 Fault Found:
    008598 - Oxygen (Lambda) Sensor B1 S1
    P2196 - 000 - Signal too High (Rich) - MIL ON
    Freeze Frame:
    Fault Status: 11100000
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 255
    Mileage: 154167 km
    Time Indication: 0
    Date: 2011.07.19
    Time: 08:31:44
    Freeze Frame:
    RPM: 1702 /min
    Speed: 89.0 km/h
    Lambda: 47.3 %
    Mass Air / Rev.: 550.0 mg/str
    Voltage: 0.825 V
    (no units): 16.0
    Voltage: 0.975 V
    Readiness: 1 1 0 0 0
    Any advice on what I could do?
  2. Keithuk
    7,029
    VAG Error Code: 08598/18628/008598/5119/5120/5121
    EOBD II Error Code: P2196
    Fault Location:
    Oxygen (Lambda) Sensor 1 (G39), Bank 1 - Signal Stuck Rich/Signal too High (Rich)
    Possible Cause:
    Excessive Fuel Consumption.
    Vacuum leaks.
    Wiring/Connector(s).
    Oxygen (Lambda) Sensor 1 (G39).
    Fuel pressure.
    Injectors.
    Air intake restricted.
    Possible Solutions:
    Check/Replace Oxygen (Lambda) Sensor 1 (G39), Bank 1.
    Description:
    The front Oxygen (Lambda) Sensor 1 (G39) is placed into the exhaust manifold. It detects the amount of oxygen in the exhaust gas compared to the outside air. The Oxygen (Lambda) Sensor 1 (G39) has a closed-end tube made of ceramic zirconia. The zirconia generates voltage from approximately 1V in richer conditions to 0V in leaner conditions. The Oxygen (Lambda) Sensor 1 (G39) signal is sent to the Engine Control Module (ECM). The Engine Control Module (ECM) adjusts the injection pulse duration to achieve the ideal air-fuel ratio. The ideal air-fuel ratio occurs near the radical change from 1V to 0V.
  3. TDISportAaron
    Jan 10, 2017
    13
    UK
    I cleared the code at lunch time and took the car for a 20 minute spirited drive to get temperatures up, incase of buildup of carbon.
    Anyway.... no return of the code yet but it's early days.
