Overboost troubles
Discussion in 'VW Mk4 Jetta, Golf, New Beetle, Passat TDI forum' started by xcr600man, Dec 27, 2016.
  1. xcr600man
    xcr600man New Member
    Mar 14, 2011
    4
    2003 Jetta TDI
    My 03 Jetta TDI has been going into limp mode constantly. Only way it doesn't is if I watch my boost gauge and not let it stay over 10 psi very long. Has a new actuator, all new vacuum lines, new N75valve. It's making plenty of boost. At wide open it will make 22 psi. Seems like it should have more power than it does. It just won't bleed off. I use to hear it bleed off thru my boost gauge so I know it's definitely not bleeding off now. Any ideas???
    Oh and it's all stock
  2. Erich
    Erich New Member
    Jun 28, 2015
    18
    Vw Jetta tdi 2000
    burlington
    Sounds like the vanes are not freely opening and closing. Might want to Check adjustment of the actuator arm and or whether the vanes are carboned up preventing the actuator to fully move back and forth freely.
  3. xcr600man
    Mar 14, 2011
    4
    2003 Jetta TDI
    Would I get 22 psi if they were?
  4. Erich
    Erich New Member
    Jun 28, 2015
    18
    Vw Jetta tdi 2000
    burlington
    If the actuator is unable to move the vanes to relieve some pressure I guess it would over boost yes
  5. crsmp5
    crsmp5 Well-Known Member
    Feb 14, 2012
    1,277
    85 kubvan
    22psi is overboost... so.. what do you not understand?
  6. xcr600man
    Mar 14, 2011
    4
    2003 Jetta TDI
    I thought it wouldn't have boost at all. Sorry
  7. xcr600man
    Mar 14, 2011
    4
    2003 Jetta TDI
    Where is the best place to send them out for rebuild?
  8. koabi
    koabi Member
    May 12, 2012
    69
    1998 Jetta TDI, 2003 Jetta Wagon TDI
    Tucson, AZ
    you probably don't need a rebuild.
    Your new N75 valve certainly helps, but if the vacuum line from N75 to the actuator isn't good then it doesn't matter. (Does no vacuum mean fail with vanes open or closed guys?)
    If you can, disconnect the actuator from the lever and see if the lever moves freely. Should have about 1/2" of travel. If it doesn't your vanes might look like mine did:
    chitty made a good diagnostic video too if you haven't seen it yet:
  9. crsmp5
    Feb 14, 2012
    1,277
    85 kubvan
    had someone pay me to do ez off method once... id never do it to my own car.. but can try it...
    http://www.xsboostturbochargers.com/
    is a guy who ive had rebuild quite a few turbos... i went to his shop 1st time to check him out and his equipment.. not a half ass shop in any way.. they hand file to fit the oil seals and balance every turbo.. and sandblast/make it look new too...
  10. VW_TDi
    VW_TDi Member
    Jun 17, 2014
    30
    2005 Passat TDI, 2001 Jetta TDI
    California
    This is what I did to my own car about 2 years ago and it helped after swapping all vacuum lines & the N75 valve. I wasn't a big fan of it, but I needed a quick temp fix that would get me to work and back.
