Oil pump
Discussion in 'New TDI forum member introductions' started by Mickd, May 6, 2017.
  1. Mickd
    Mickd New Member
    Apr 3, 2017
    Audi A4 2tdi
    Lincolnshire
    Hi everyone, just had new balance shafts fitted to my Audi pd140. While it was off I changed the timing belt, water pump, alternator and engine mounts. Got it running and, the egr valve motor started rattling...... so, removed and cleaned all the gunk out. Fitted everything back, same noise. Think the motor spline is stripped..?. Anyway I've unplugged the pin connection for powering it up. The egr flap is in the shut position. Took it for a drive, running perfectly. Management light has come on tho. No signal from egr. Am I ok doing this.??... cheers mick.
  2. Keithuk
    7,091
    welcometomyturbodies
    What error codes are you getting as you haven't posted a report?
  3. taulant sokoli
    taulant sokoli New Member
    Mar 30, 2015
    10
    VW passat 2006
    kosovo
    Hello and welcome to my turbo diesel, you have to replace your egr cause your car will go in limp mode and you will have loss of power .
