Oil light flashes after oil change
Discussion in 'Mk5 VW Jetta, Sportwagen, and Audi A3 TDI forum' started by Denny Z, Jul 20, 2017.
  1. Denny Z
    Denny Z New Member
    Sep 5, 2016
    Volkswagen jetta tdi 2005
    Monroeville pa
    I have changed the oil in my 2005 Jetta TDI and each time the oil light will beep and oil light on dash flashes. How do I get it to stop ? The oil filter is in correctly and the oil is at the correct level.
  2. Keithuk
    7,026
  3. gt4494
    gt4494 Active Member
    Jan 15, 2011
    425
    2005 NB
    Southeast Coast on I-95. Radar detector on and yes Herbie still gets 40mpg at 80 mph
    I would first check the wire to the sensor. You may inadvertently knocked it loose off..
  4. Keithuk
    7,026
    If the oil pressure switch wire is disconnected then it won't light the warning light its earthed through the oil pressure switch.
  5. gt4494
    Jan 15, 2011
    425
    2005 NB
    Interesting! My BEW will not shut up if the wire is loose. I converted to a mechanical Guage without a "T" and had to run the sender wire to ground to stop the beeping/light.
  6. audi1z
    audi1z Member
    Oct 16, 2010
    400
    Audi 80 1Z Engine
    Up to a certain model year the TDI engines had two oil pressure switches, one closing at a minimum pressure (idle speed), the second opening at about 2000 rpm (again at a requested minimum pressure ).
    This was changed by Volkswagen with newer models to one switch.
    You need to know which version of oil pressure control is used in your car --> factory repair manual.
