Nox problem
Discussion in '2012-2016 VW Passat TDI forum' started by Nathan Hinder, Jul 13, 2017.
  1. Nathan Hinder
    Nathan Hinder New Member
    Jul 13, 2017
    2014 passat
    hamilton ontario
    Would any one know if I just need a new nox Sensor module or do is my heater shot too thanks for the help
    Thursday,13,July,2017,20:35:33:06947
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
    VCDS Version: 17.1.3.0 HEX-V2 CB: 0.4336.4
    Data version: 20170320 DS267.7
    www.Ross-Tech.com
    Chassis Type: A3 (7N0)
    Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F
    52 56 62 72 77
    VIN: 1VWCN7A36EC045852 Mileage: 138180km-85861miles
    05-Acc/Start Auth. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    2B-Steer. Col. Lock -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: OK 0000
    37-Navigation -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: Malfunction 0010
    47-Sound System -- Status: Malfunction 0010
    4F-Centr. Electr. II -- Status: OK 0000
    52-Door Elect, Pass. -- Status: Malfunction 0010
    56-Radio -- Status: Malfunction 0010
    Address 01: Engine (J623-CKRA) Labels: 03L-906-012-CKR.clb
    Part No SW: 03L 906 012 DE HW: 03L 907 309 S
    Component: R4 2,0L EDC H24 8401
    Revision: 71H24--- Serial number:
    Coding: 001D0012842400008000
    Shop #: WSC 63070 001 1048576
    ASAM Dataset: EV_ECM20TDI01103L906012DE 004008
    ROD: EV_ECM20TDI_VW41.rod
    VCID: 6A8ECBFA1CFE5B6793D-803E
    4 Faults Found:
    18624 - NOx Sensor 1 Bank 1
    P2201 00 [237] - Implausible Signal
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 138129 km
    Date: 2017.07.13
    Time: 15:24:00
    Engine speed: 1035.50 /min
    Normed load value: 0.0 %
    Vehicle speed: 18 km/h
    Coolant temperature: 98 °C
    Intake air temperature: 23 °C
    Ambient air pressure: 980 mbar
    Voltage terminal 30: 14.340 V
    Unlearning counter according OBD: 40
    Air mass: actual value (mg/stroke): 535.1 mg/stroke
    Mean injection quantity: 0.00 mg/stroke
    EGR Vacuum Regulator Solenoid Valve: activation: 100.00 %
    NOx emission NOx sensor 1: 0 ppm
    Air mass for release of NOx sensor 1 offset test: 301.4 g
    Calculated efficiency of NOx conversion: 0.825
    18627 - NOx Sensor 1 Bank 1
    P2200 00 [096] - Electrical Malfunction
    Intermittent - Not Confirmed - Tested Since Memory Clear
    18640 - Sense Circuit for Heater for NOx Sensor 1 Bank 1
    P2209 00 [096] - Implausible Signal
    18648 - NOx Sensor 1 Bank 1
    P2201 00 [101] - Implausible Signal
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 138154 km
    Date: 2017.07.13
    Time: 16:01:34
    Engine speed: 1522.00 /min
    Vehicle speed: 50 km/h
    Coolant temperature: 99 °C
    Intake air temperature: 28 °C
    Voltage terminal 30: 14.260 V
    Air mass: actual value (mg/stroke): 253.4 mg/stroke
    EGR Vacuum Regulator Solenoid Valve: activation: 56.98 %
    Air mass for release of NOx sensor 1 offset test: 0.0 g
    Calculated efficiency of NOx conversion: 0.732
    Readiness: 1 1 0 0 0
  2. Keithuk
    7,235
    If you have a genuine VCDS cable and registered it then join Ross-Tech forum and make a new thread with a full AutoScan. There are NOx problems on there but you can't search for NOx as its only 3 characters.
