Non PD to PD conversion ASV to ASZ
Discussion in 'General Diesel Discussion' started by A.m.C, Apr 22, 2017.
  1. A.m.C
    A.m.C New Member
    Aug 12, 2011
    10
    Seat Ibiza TDi Sport 2002
    Hi all, not posted for a long time!!
    After some help, partway through the above swap but cant find pin outs on the ECUs, ive stripped a donor car for parts and i have it all but not sure what to do about wiring, read you can use the non PD loom as only some differences?
    Sent from my SM-G935F using Tapatalk
  2. Keithuk
    7,235
    Manufacturer: Seat, Date(s) Used: 03/1999-05/2002, Model: Ibiza/ST, Engine Code: ASV, 81Kw, 110PS, 1.9 Ltr, 4 Cyls , Remarks: Turbocharged Direct Injection (TDI)
    Manufacturer: Seat, Date(s) Used: 05/2005-09/2005, Model: Ibiza/ST, Engine Code: ASZ, 96Kw, 131PS, 1.9 Ltr, 4 Cyls , Remarks: Turbocharged Direct Injection Pumpe Düse (TDI-PD)
    These engine codes are used in other VAG models.
    Have you google it the ecu pin configuration?
    I could check ElsaWin to see any differences if you post your Type Code?
  3. A.m.C
    A.m.C New Member
    Aug 12, 2011
    10
    Yeah ive googled for a couple of hours and come up dry, ive got elsawin but its proving difficult to work out the pin outs as ive not used the program before haha what type code do you need? Mayne youll have more luck!!!
  4. Keithuk
    7,235
    What I've found with older models on ElsaWin as it doesn't show much electrical details.
    The Type Code or as ElsaWin calls it Sales Model is the 6 character number on the top of the data sticker.
    Options Sticker and Engine Codes
  5. Seatman
    Seatman Well-Known Member
    Jul 9, 2010
    5,827
    Scotland
    PP764's, turbo and mapping
    I usually find info googling the ecu part number, places like ecu connections often have good info too
  6. A.m.C
    A.m.C New Member
    Aug 12, 2011
    10
    Will give that a try, ive started making a spreadsheet and have found a lot of info on elsawin so far but im.hours in and barly halfway through one loom haha
  7. Keithuk
    7,235
    A spread sheet isn't much use when you copy & paste info from ElsaWin, Word is great.
  8. Keithuk
    7,235
    I had a look for 2002 Seat Ibiza 1.9 TDI SIGNO2P8 6K13X6 ASV - 110PS. I doesn't show anything for the ecu. The other things is shows you can't copy & paste.
