NO HEAT
Discussion in '2012-2016 VW Passat TDI forum' started by LRP3, Nov 13, 2017.
  1. LRP3
    LRP3 New Member
    Nov 13, 2017
    2014 VW Passat TDI
    PA
    I have 2014 Passat TDI with no heat coming from vents. I flushed the heater core and it has great flow. Where do I go next to regain heat? Car gets to 190 degrees without issue. Hoses feel hot as does fill container just no cabin heat.
  2. borovica
    borovica New Member
    Saturday
    2014 Passat TDI Comfort line
    Toronto
    I have 2014 Passat TDI with 92000 km and experiencing since Nov 18th the same problem. The first thing I noticed there was no heat hot air blowing at all, only cold air blows even with heat setup and second check engine light showed up! The emission software got updated 2 days ago and two recalls, so not sure if these caused any issue?
    Prior to this on 66000 km the heater on passenger side didn't work, resulted in changing heater core,gasket set and adding coolant. So on 71000 km the drivers side blows heat hot air even with A/C on, resulted in replacing left temperature flap servo (motor and lever)..
