No Clutch Pedal Pressure after bleeding
Discussion in 'Mk5 VW Jetta, Sportwagen, and Audi A3 TDI forum' started by semiret, Jun 15, 2017.
  1. semiret
    semiret New Member
    Apr 7, 2014
    15
    Audi A3 Sportback 1.9tdi sport 2005my
    UK Hampshire
    Audi A3 8PA bkc manual 2005
    Hope you can help. Brake fluid needs changing so started with the clutch. I used a 20psi pressure bleeder and removed about 100ml which had air bubbles. Decided to stop as air still showing and tightened the bleed valve. The brake fluid resevoir hardly dropped. I now find that I do not have any pressure in the clutch pedal, it just drops to the floor so no clutch. What have I done wrong and is there anything I can do to correct this? A simple job has turned into a nightmare.
    Many thanks
  2. ncsteinb
    ncsteinb New Member
    Dec 11, 2013
    22
    2006 BRM Jetta Manual, 2002 ALH Jetta Manual, 1997 318ti w/turbo 6cyl (M50) swap
    Saginaw, MI
    Koni Yellow adjustable dampers, H&R Sport Springs, ECS Tuning Dogbone insert, ECS Single Mass Flywheel (both), EGR delete (both), Malone tune (both), BMW-> All of the mods!
    The pressure bleeder will replace the brake fluid that is pushed out (that is if you put brake fluid in the pressure bleeder). The level not changing is normal.
    Keep bleeding it till you don't see any more bubbles. You can also try the "helper" method, just make sure to give them a beer while they press the clutch while you actuate the bleeder screw.
    Cheers
    semiret likes this.
  3. semiret
    semiret New Member
    Apr 7, 2014
    15
    UK Hampshire
    ncsteinb.... many thanks for the reply, all fine now.
