Newby from Twisp WA
Discussion in 'New TDI forum member introductions' started by Ed Welch, Oct 27, 2017.
  1. Ed Welch
    Ed Welch New Member
    Oct 27, 2017
    VW Passat Wagon TDI 2005
    Twisp, Washington
    Hello, I am the original owner with my wife of a 2005 Passat Wagon TDI with 235K. I love the car and just replaced the timing belt but did not replace the chain drive that people are mentioning. I recently started having trouble with the transmission. First about 3 weeks ago the reverse stopped working and now the forward drive is slipping which it did not do until today. I have only used it to make a few trips to town since the reverse quit working. There is no dealership nearby, and the nearest tranny shop is about 100 miles away in Wenatchee. Would it be useful to get it to Wenatchee to check for codes or should I assume that I need to replace the tranny. I can find someone locally to replace the tranny.
  2. Keithuk
    7,130
    welcometomyturbodies
    That year can have a 1.9 or 2.0 TDI which one is in your? You can add that to your car spec? ;)
    It sounds like you have a 6 speed DSG.
    You need to get your motor scanned (preferably with VAG-COM\VCDS) for any error codes logged in the ecu and post them, that will save a lot of guessing.
    I'm told that AutoZone will do a free scan in the hope you buy something of them.
  3. Ed Welch
    Ed Welch New Member
    Oct 27, 2017
    Twisp, Washington
    Thank you. I will try to get a scan done with a local mechanic, and I will check through the owners manual to see if it will say which transmisssion I have.
  4. Dave N
    Dave N Member
    May 31, 2015
    53
    06 Golf TDI BEW 09A
    Spokane Wa
    If it was me I would call the shop in Wenatchee and and see if they are set up to check VCDS otherwise your nearest dealers are gonna be in Spokane or Kelowna. Looks like the Methow is gonna get hit with snow next weekend so you might want to jump on that soon.
