Need new key and FOB
Discussion in 'Mk5 VW Jetta, Sportwagen, and Audi A3 TDI forum' started by JE85, May 18, 2017.
  1. JE85
    JE85 New Member
    May 18, 2017
    2006 VW Jetta TDI 1.9 BRM 5 speed manual
    Meriden CT
    I just bought a 2006 jetta tdi brm 5 speed manual with a 146k on it.
    The seller only had one key and the keyless entry fob does not work.
    I tried replacing the batteries but it still does not work.
    I had seen a video showing how to reprogram them with 1 key in the ignition and 1 in the door lock but I only have the 1 key.
    Is my only option going to the stealer?
    I have not been able to convince my self on spending $200+ on a vcds yet especially when I have a new clutch and timing belt planed in the near future.
    23,901
    Dealer will charge you 1 hour, or about 130+ tax. VCDS seems like a good buy compared to that. Keep in mind that if you wish to get a new key you also need to program the immobilzer, see the mk5 key FAQ for detailed steps.
  3. thzpcs
    thzpcs Member
    Jun 30, 2016
    70
    2008 Golf TDI
    Golden, CO
    These guys have it much cheaper, about $103 for a new key, and then they're usually pretty cheap to cut and reprogram. My dealer only charged $50 to cut and reprogram my key.
  4. xeno555
    xeno555 Well-Known Member
    Dec 12, 2011
    1,684
    2012 TDI Tech Package 6mt
    Mile High
    Some dealers will not touch a key unless you bought it from them.
  5. firehawk618
    firehawk618 New Member
    Jul 24, 2011
    8
    2001 Passat B5.5
    My local dealer wants $260 for a remote key or $130 for a valet key. This includes programming. They do not cut them. They order the key from VW.
    They wanted $135 for the remote key and $70 for the valet key by themselves with no programming.
    That's $125 for them to program a key / learn a remote or $60 to program a valet key.
    Keep in mind you cannot program keys even with Vagcom unless you have your cluster's SKC "secret key code".
    Depending on the cluster you have you may be able to retrieve it with black market tools. Vagcom cannot get you the SKC and neither can the dealer.
