MK7 TDI GOLF Oil Change question
Discussion in 'Mk7 VW Golf, Sportwagen and Audi A3 TDI forums' started by JeffsGolfTDI, Nov 22, 2015.
  1. JeffsGolfTDI
    JeffsGolfTDI Member
    Sep 23, 2014
    32
    2015 VW Golf TDI S
    Colorado Springs
    I could not locate where the smaller o ring goes, that came with the new filter? Anyone done there own oil in a 2015 Golf or Jetta TDI? I looked all over the internet, could not get an answer.
    Thanks for the help.
  2. Keithuk
    7,078
    What's the part number of the OEM oil filter? There was only 1 large one in mine for the cover top.
    There are oil change descriptions in TDI Wiki if you search.
  3. JeffsGolfTDI
    JeffsGolfTDI Member
    Sep 23, 2014
    32
    2015 VW Golf TDI S
    Colorado Springs
    Ok Thanks for your help. I ordred from IDparts. It had a large and a small o ring. Only saw a large one on the cap. OEM Part Number: 03N115562
    Manufacturer Number: OX787D
  4. Vwman2015
    Vwman2015 Member
    Oct 3, 2015
    302
    Vw golf, mk5 2005 sdi, bkd engine
    Clacton
    It goes on the bottom stem of the filter where it sits in the oil filter housing, bottom of filter.
  5. mikeme
    mikeme Active Member
    Jan 29, 2013
    637
    2009 JSW TDI
    Northern Virginia
    Not on the 2015.
    the oil filter cover includes a small plug that lets you drain the oil from the filter, the small o ring is to replace that one.
    the large one, of course, goes on the large filter cover.
  6. mikeme
    Jan 29, 2013
    637
    2009 JSW TDI
    Northern Virginia
  7. mikeme
    Jan 29, 2013
    637
    2009 JSW TDI
    Northern Virginia
  8. Keithuk
    7,078
    Oil filter with gasket for CRUA, DEJA diesel - 03N 115 562 - £9.20. It looks like it includes the small O ring at the bottom because it doesn't show a separate part number.
  9. JeffsGolfTDI
    JeffsGolfTDI Member
    Sep 23, 2014
    32
    2015 VW Golf TDI S
    Colorado Springs
    Thank you for the diagrams and photo's. I looked on the internet with no luck. I wanted to stay away from the stealership. I'll replace small o ring next oil change :)
    Thanks again for the help!
  10. mikeme
    Jan 29, 2013
    637
    2009 JSW TDI
    Northern Virginia
    You don't have torque values for the cap and plug, do you?
  11. Keithuk
    7,078
    I would think its the same as mine. Oil filter Cap, 25 Nm, 18.5 lb/ft
  12. mikeme
    Jan 29, 2013
    637
    2009 JSW TDI
    Northern Virginia
    The small drain plug that fits into the end of the filter cover has detents which click on the way in. just wondering if there is a torque specified for it.
    with the O ring, small thread size and detents, I would expect it is not very high. The detents should keep the cap installed, and the O ring seals between the outer diameter of the drain plug, and the inner diameter of the plug.
  13. Jamesfg77
    Jamesfg77 New Member
    Jun 8, 2017
    2015 VW Golf S TDI
    Indianapolis, IN
    Solo-Werks S1 coilovers 18x9 Alzor Wheels w/ContinentalExtremeContact DWS06 tires
    5NM according to Alldata Pro
  14. mikeme
    Jan 29, 2013
    637
    2009 JSW TDI
    Northern Virginia
    turns out it also is written on the cap.
    Thanks
  15. mikeme
    Jan 29, 2013
    637
    2009 JSW TDI
    Northern Virginia
  16. JeffsGolfTDI
    JeffsGolfTDI Member
    Sep 23, 2014
    32
    2015 VW Golf TDI S
    Colorado Springs
