Missing oil galley plugs in the rocker arms
Discussion in 'Mk5 VW Jetta, Sportwagen, and Audi A3 TDI forum' started by gtturbo, Apr 16, 2015.
  1. gtturbo
    gtturbo New Member
    Oct 12, 2012
    4
    Jetta TDI 2006
    Replacing cam on a 2006 TDI Jetta and the plug pictured below is MISSING. Any idea where I could get a replacement?
    NOTE: While removing the old cam inspect the oil galley plugs in the rocker arms. They sometimes have a tendency to fall out randomly over time and pressure. This one was laying inside the head when rockers and cam where removed.
    [​IMG]
  2. fxk
    fxk Member
    Mar 18, 2015
    48
    2014 VW JSW TDI
    Vast wilderness between DC and B'more
    Falls out randomly over time and pressure? Really? :panic
    I'd think about tapping the hole and putting in a setscrew.
    frank
  3. gtturbo
    gtturbo New Member
    Oct 12, 2012
    4
    Jetta TDI 2006
    Thanks, sounds like a reasonable way to deal with it.
  4. xeno555
    xeno555 Well-Known Member
    Dec 12, 2011
    1,684
    2012 TDI Tech Package 6mt
    Mile High
    Or deform edge of hole.
  5. Nick Broersma
    Nick Broersma New Member
    May 10, 2015
    VW Caddy 1.9 TDI
    Netherlands Amsterdam
    Hello gtturbo,
    I have the same problem with my VW Caddy 1.9 TDI from 2006.
    I wondered what solution did you choose and did it work?
  6. gtturbo
    gtturbo New Member
    Oct 12, 2012
    4
    Jetta TDI 2006
    Nick, I took the rocker to a machine shop and they turned down a new plug on a lath. We used red lock-tight and than drove in the new plug. Defiantly a tight fit . Than we used a punch and put four or five divots around the hole to slightly decrease the oppening . There was a discussion on tapping the rocker but the risk of breaking a tap in the hardened rocker was not very appealing.
    Hope this helps
  7. Ol'Rattler
    Ol'Rattler Well-Known Member
    Apr 24, 2011
    833
    06 TDI Jetta
    Marysvile, WA.
    Pretty common on the BRM's I would suspect. On mine, the most forward and aft plugs were sitting in head bolts when I changed the cam. My fix was to glue them in place with JB Weld.
  8. MyTdi2
    MyTdi2 New Member
    Jul 15, 2015
    VW Jetta TDI, 2004
    Pearisburg VA
    I found one of those plugs a while back when I had the valve cover off. I had no idea what it was, until I found this. I guess those oil gallery plugs are very important, right? Does the camshaft not get enough oil if a plug is missing?
  9. Nick Broersma
    May 10, 2015
    VW Caddy 1.9 TDI
    [​IMG]
    It is easy to fix. A friend weld it. Price was round 30 euro. But it is important that the holes are closed.
  10. MyTdi2
    MyTdi2 New Member
    Jul 15, 2015
    VW Jetta TDI, 2004
    Pearisburg VA
    Thanks Nick, Welding it would definitely be the best way to fix it. I put it back in with some thread locker.
  11. g.a.meek
    g.a.meek New Member
    Feb 18, 2015
    2009 Jetta TDI
    Edmonton, Alberta, Canada
    Nick:
    I was changing my camshaft on my BRM Jetta TDI, and after reading your post about loose plugs, found the plug
    from the oil gallery of the injection rockers had fallen out. Poor workmanship on VW's part. Anyway, I cleaned the
    hole in the end of the injection rockers and degreased it and the plug. Then I put threadlocker on everything, and
    pushed it back in. Then I took a 2 mm diameter punch and drove the plug a little to expand the plug in place. I hope
    it never comes out, as it would be disastrous to have the injection rockers starved for oil. Thanks for your post, as
    otherwise I would not have checked the oil gallery plugs, as I assumed that they were always installed well enough
    for life, and would never have come out...! g.a.meek
  12. Ol'Rattler
    Apr 24, 2011
    833
    06 TDI Jetta
    Marysvile, WA.
    Very bad idea. Welding will change the heat treat of the metal.
