Manual Passat - problems with clutch
Discussion in '2012-2016 VW Passat TDI forum' started by CarEnthusiast, Jan 26, 2017.
  1. CarEnthusiast
    CarEnthusiast New Member
    Jan 16, 2017
    VW passat 2014
    Atlanta, GA
    Hey everyone,
    I've got a 2012 Passat SE, 2.5 L with manual gearbox. And recently I noticed that when I hit my clutch pedal and start changing gears, there is a sort of shaking pedal feel. Plus, downshifting became way harder. I had the cable changed recently, so I am pretty sure it's fine... Can it be due to worn out lever? Or what other parts should I check to determine what's the case here?
    Thanks...
  2. Erich
    Erich New Member
    Jun 28, 2015
    18
    Vw Jetta tdi 2000
    burlington
    Check cable adjustment. Clutch might not be fully disengaging.
  3. xeno555
    xeno555 Well-Known Member
    Dec 12, 2011
    1,661
    2012 TDI Tech Package 6mt
    Mile High
    No cable, all hydro.
    Causes:
    Warped disk, flywheel
    Worn motor/tran mounts.
    Failing DMC
  4. CarEnthusiast
    Jan 16, 2017
    VW passat 2014
    Atlanta, GA
    Thanks for replying, folks. Last night had a tech look into this, and he said that the clutch lever is no good anymore. So had to order a new one. Hopefully it will arrive early next week, so that I could get it in as soon as possible, as such clutch and gearbox operation drives me nuts.
  5. CarEnthusiast
    Jan 16, 2017
    VW passat 2014
    Atlanta, GA
    A quick update - got my lever with Saturday delivery (https://www.carid.com/clutch-levers/), and am glad everything seems to work fine. In case someone needs the number - here's what is writtem on my box: W0133-1734819-OES
    Cheers!
  6. JazzBeBop
    JazzBeBop Member
    Oct 9, 2010
    66
    2015 Passat TDI SE Fortana red on beige
    Grand Prairie, TX
  7. xeno555
    Dec 12, 2011
    1,661
    Mile High
    Cool, that rarely fails and can be caught be visual inspection.
    Goodluck
