Main bearing cap tolerance Passat B5.5 TDI
Discussion in 'VW Mk3 Jetta, Passat TDI and other/older diesels' started by Eric Delling, Jan 31, 2017.
  1. Eric Delling
    Eric Delling New Member
    Jan 10, 2017
    6
    2005 Passat TDI
    Sacramento
    Anyone know what the tolerance is supposed to be when using the plasti-gadge.
    Motor was driven 3 city blocks with oil light on. When tested at idle --- oil pressure was like 4 or 5 psi (very low) did not test under load for fear of causing further damage!
    Looks like the "key-thingey" in the oil-pump is slightly rounded.
    23,902
