LED strip light indictor in door mirror
Discussion in 'General Diesel Discussion' started by Keithuk, Jan 4, 2017.
  1. Keithuk
    6,986
    I'm posting this in General because it isn't only a Mk6 Golf problem as the same type of light is fitted to other models.
    I've had an error code for a few months. The indictor strip light works on both mirrors so I haven't really bothered about it. Last week I noticed the light in the drivers door the one with the fault code isn't as bright. VW in there stupid wisdom don't show these LED bulbs as a replacement item you have to buy a new light unit. I was going to count the number of LED lights when I went out today but I forgot. I think there are 5 or 6.
    Turn signal indicator left - 1K5 949 101 - £37.03
    Turn signal indicator right - 1K5 949 102 - £37.03
    This is stupid you have to buy a new light if the bulb goes, I believe its the same for the rear fog light LED which you don't have in the States.
    I've google it LED amber bulb strip 12v. There are sellers on fleabay
    http://www.ebay.co.uk/itm/4x12LED-1...957639?hash=item33bde0c9c7:g:-SUAAOSwawpXvkH8
    http://www.ebay.co.uk/itm/12-YELLOW...hash=item5688830b2f:m:mjMzmjSqa7cYFOjeOjh6iWA
    I was wondering if anyone else has had the error code or replace the LED bulbs in the mirror?
    VAG Error Code: 00109
    Fault Location:
    Turn Signal Lamp: Driver, Left Mirror (L131) - Electrical Fault in Circuit
    Possible Cause:
    Wiring/Connector(s).
    Voltage Supply for Left Mirror Turn Signal Lamp (L131) faulty.
    Possible Solutions:
    Check Voltage Supply for Left Mirror Turn Signal Lamp (L131).
    Check Left Mirror Turn Signal Lamp (L131) Operation.
  2. Keithuk
    6,986
    45 views and no comments.
    I've check other models and they use the same.
    Mine turn signal indicator right 1K5 949 102 £37.03 http://nemiga.com/cat_spares/etka/volkswagen/golf/649/941400/
    Golf V 2008-2009 turn signal indicator right 1K1 949 102 £28.51
    Golf 2009 turn signal indicator right 1K1 949 102 £37.03
    Golf 2009-2013 turn signal indicator right 1K5 949 102 £37.03
    Jetta 2009-2017 turn signal indicator right 5C6 949 102 £37.03
    Passat 2008-2011 turn signal indicator right 3C0 953 042 J £55.43
    Passat CC 2009-2011 turn signal indicator right 3C8 949 102 D £34.20
    Touran 2009-2010 turn signal indicator right 3C8 949 102 D £36.00
    Touareg 2009-2010 turn signal indicator right 7L6 949 102 C £58.46
    As no one tried these LED strips?
    The Ministry of Transport (MOT) test is due at the end of month so it looks like I will have to buy a new unit. This is another reason I shouldn't have bought a VW. Along with Dual Mass Flywheel (DMF), Diesel Particulate Filter (DPF) and the drivers seat.
  3. Sudhir Saxena
    Sudhir Saxena New Member
    Dec 1, 2010
    16
    VW Golf TDI MK7 Highline DSG
    Markham, Ontario, Canada
    None
    Hello Keith;
    If left LED turn indicator on mirror is dim, then you can try cleaning contacts by removing mirror. I had this happened to me once on my 2009 Jetta ( Petrol engine).
  4. Keithuk
    6,986
    Fitting one of these LED strips in would have been no good as its a sealed unit.
    There is nothing in ElsaWin about mirrors only wiring.
    I checked the contacts all clean and there is battery voltage to it. I had to order a new unit from my dealer.
    Turn signal indicator right - 1K5 949 102 - £34.20
    You need a T10 Torx screwdriver.
    Its fitted to the black plastic bottom mirror cover, extra cost that's not needed.
    While I was there I had a couple of wiper blades (as they are now 7 years old, that because I clean them with methylated spirits), the passenger side is shorter than the drivers side, which is stupid as you can't swap them if one doesn't wipe as good.
    1 set aerodynamic wiper blades driver and passenger - 1Q1 998 002 - £34.12
    There are a couple of video's on YouTube.
