Key Programming Questions
Discussion in 'VW Mk4 Jetta, Golf, New Beetle, Passat TDI forum' started by eddi887, Jan 2, 2018.
  1. eddi887
    eddi887 Member
    Jun 18, 2017
    50
    2003 Jetta TDI
    Dale Texas
    Air intake
    Hi All,
    I've been looking around the site for information on programming a key for a 2003 Jetta TDI. I ordered a key and fob from fixmyvw. I bought VCDS a while back, so will it do all the programming I need, or do I need to rent the cable the fixmyvw?
    Thanks...Jeff
  2. Keithuk
    7,235
    Do you have a genuine VCDS cable or a Chinese cloned cable? Either way VCDS won't programme keys without the Secret Key Code (SKC). There are a couple of software and cable VAG-TACHO and VAG K+CAN Commander that should find the SKC and programme your new key. google it
  3. eddi887
    eddi887 Member
    Jun 18, 2017
    50
    2003 Jetta TDI
    Dale Texas
    Air intake
    Thanks Keithuk,
    I bought it from Ross-Tech, so yes it's genuine. I'll check into the other cables then. Is there a specific version for vag-tacho that I would need?
    Thanks again...Jeff
