Jetta Mark V Axle Replacement--Are Genuine VW Axles Worth It?
Discussion in 'Mk5 VW Jetta, Sportwagen, and Audi A3 TDI forum' started by AirLand&Sea, Oct 11, 2017.
Tags:
  1. AirLand&Sea
    AirLand&Sea New Member
    Nov 18, 2012
    29
    I will need to replace front axles on my 2006 Jetta TDI. The VW axles are significantly more expensive than aftermarket. Are they worth it or are there particular aftermarket brands that are just as good? Any advice is appreciated.
  2. Ol'Rattler
    Ol'Rattler Well-Known Member
    Apr 24, 2011
    828
    06 TDI Jetta
    Marysvile, WA.
    The dealers are OEM, however, they are super expensive. The local parts houses sell Chinese garbage that are pretty dismal by comparison. If you desire OEM, go here: https://www.idparts.com not your local dealer.
    People have had very good results with these. https://www.raxles.com :cool:
    Worth repeating, Parts house axles usually are Chinese garbage.
  3. AirLand&Sea
    Nov 18, 2012
    29
    Ok thanks. Understood. This verifies what some others have advised. Do I have to replace the axle bolts or can I re-use the originals?
  4. Ol'Rattler
    Apr 24, 2011
    828
    06 TDI Jetta
    Marysvile, WA.
    Correction courtesy of Dave N. Item 14: Bolts-always replace.
    They are torqued to:
    • Pre tighten to: 7 FT LBS
    • Final torque: Tighten in a criss cross pattern to 30 FT LBS for M-8 bolts and 52 FT LBS for M-10 bolts
    Some people have problems with them coming loose after some miles most likely because they didn't use a torque wrench and/or reused the bolts.
  5. Dave N
    Dave N Member
    May 31, 2015
    48
    06 Golf TDI
    Spokane Wa
    Yes you need to replace the bolts as they are torque to yield. I also recommend going with Raxels and if you do they include new bolts and the triple square tool for removing/installing them
  6. AirLand&Sea
    Nov 18, 2012
    29
    Ok. One more question. Is realignment necessary after replacement? I see that I need to remove the three lower ball joint bolts to swing out the wheel bearing assembly. Struts will remain in place for now.
  7. Keithuk
    7,094
  8. terpsgeorgia
    terpsgeorgia Member
    Nov 26, 2016
    32
    06 Jetta TDI
    Cleveland, Georgia
    I don’t mean to be contrarian, and I have never replaced a VW axle (have on an A6), but I have replaced a dozen or so over the years for myself and friends. I have never had a ‘parts store’ axle go bad. In fact, I have never had to replace them more than once on a car. Usually they last to 100k - 150k. The most miles I have driven a car is 220k so never got to the point of doing a second replacement. I would not argue against OEM parts generally being of better quality but for a 11 year old car, I am not sure what you get from the OEM is "OEM quality" any longer.
    I would caution against the really cheap ones on amazon or eBay. My experience with those parts in general (not axles specifically) has been they are definitely lower quality.
  9. Ol'Rattler
    Apr 24, 2011
    828
    06 TDI Jetta
    Marysvile, WA.
    Thanks, I don't know how I missed that........................
  10. frodoz737
    frodoz737 Active Member
    Apr 26, 2014
    296
    2015 Prius Four, 2014 Corolla S, 2010 Prius II, Cimbria SS
    TX
    n/a
    Yes on Raxels, yes on new hardware and yes on alignment after. Also, "plan" to replace any bushings, ball joints, tie rod ends, links, wheel bearings, brake components, ect...that show wear while your at it.
  11. AirLand&Sea
    Nov 18, 2012
    29
    Well, I did replace two axles on a Subaru using NAPA deluxe versions which were supposedly not re-manufactured and do come with a lifetime warranty. So I suppose that means if they ever fail they will give you another one? For $70 each that was a pretty good deal and so far they appear to be working ok. I heard the GKN axles were high quality and not quite as expensive as the VW versions so might look into these. They are still around $250 each, though. The project did get bigger as now I do need to look into the bushings and the ball joints and only want to take it all apart once before the re-alignment. Oh well, the struts could use replacement as well....
