Intermittent loss of acceleration.
Discussion in 'VW Mk4 Jetta, Golf, New Beetle, Passat TDI forum' started by VDubs83, Dec 6, 2017.
  1. VDubs83
    VDubs83 New Member
    Oct 20, 2017
    2002 TDI Jetta
    St. Clair County
    New to me 2002 TDI Jetta has the most annoying loss of acceleration. Ran the car through scanner and didn't pull any codes. Happens pretty infrequently and doesn't persist for more than a few minutes. Anyone have any ideas? Or is it just due to an older car with 190k miles on it. It's a manual transmission too. Vacuum lines are the older black braided material. My first thought is to replace those. But right now the car is running great and it's 28' degrees out...colder than it's been all year.
    Thanks for any and all information.
    Sent from my Pixel using Tapatalk
  2. Vdubcaddy
    Vdubcaddy Member
    May 7, 2017
    35
    Vw caddy 2004
    Uk
    Crumbs if you struggle to work on a motor in 28 degrees cos it's cold then you should try it when it's only 4 degrees !!!!
